**Sonarr version 2.0.0.5344
**Mono version 5.20.1.34 < listed in Sonarr. Actual downgraded version installed is 5.8.1.0.r9
**OS Asustor ADM 3.4.7.RFO2
Debug logs: https://paste.ubuntu.com/p/C9DvTxPBKh/
Since updating to Sonarr 2.0.0.5344 (Initial release with Docker) episodes are not being moved nor renamed.
When adding a new series, Sonarr successfully creates a series folder at /volume1/Download/Completed_Shows/ with permissions pref set RWD (file chmod mask - 0777 and folder chmod mask - 0777).
Sonarr and NZBGet are running on the same NAS (Asustor AS5002T) so Drone Factory Options are not set (Interval 0).
Downloaded episodes are incorrectly being added to:
Instead of the intended location of:
/volume1/Download/Completed_Shows/series-title/episode
The result after adding a new series:
/volume1/Download/Completed_Shows/Breeders/
/volume1/Download/Completed_Shows/Breeders S01E01 REPACK 1080p HEVC x265-MeGusta/
I have downgraded Mono to version 5.8.1.0.r9 based on the recommendation in the changelog.
Despite the port number set at Settings > General > Port Number being 8989, the actual port number in the URL is http://192.168.86.2:18989/
Whilst the permissions of the newly created series folder are correctly set as RW (0777) for all. The newly downloaded episode folder differs with RW - Owner, and RO - Group / Others.
If I get permissions on the actual media file (.mkv) they are listed as ‘Special Permissions’.
Settings > Download Client > NZBGet > Host = 192.168.86.2. Using ‘localhost’ instead results in:
'Test was aborted due to an error: Unable to connect to NzbGet. Error: ConnectFailure (Connection refused): ‘http://localhost:6789/jsonrpc’ ’
Any advice as to where to look next would be greatly appreciated.
