Sonarr version (exact version): 2.0.0.5301 Mono version (if Sonarr is not running on Windows): 5.20.1.34 OS: Synology DSM 6.2.2-24922 Update 6 Debug logs: Description of issue:
Sonarr does not have permission to move and then remove files downloaded by sabnzbd. I have followed the guidance give here except on sc-download as that is the group created:
If I set permissions and apply to all folders, then it fixed the permission for existing folders and files, but the next show that is downloaded, Sonarr again doesn’t have permission. sc-download has full control over the folders and share. I am at a loss. Does anyone have an idea?
Similar yes, but both Sonarr and sabnzbd are running as native apps. I have to assume it is sabnzbd that is the issue when it creates the folder. I don’t know of a way to make it set or not set certain permissions on folder creation. I suspect that is the problem.
I appreciate the help. I ended up solving this by creating Docker containers for both Sabzbd and Sonarr. It seems the native packages have some bugs or eccentricities that are hard to solve. It took about 30 minutes to create the containers and configure. I spent about 8 - 10 hours trying to problems with the native apps without any luck. My suggestion would use Docker, it is much easier.
