I have some UK shows I watch that have variants (XL or Uncut) - same episode but longer/uncut versions.
For example QI (TVDB ID: 72716) also has QI XL (TVDB ID: 369316). Same series numbering, etc… I have QI added in Sonarr and it shows alternate titles of “Alternate Titles BBC QI (Quite Interesting) BBC QI”. Recently it will not download new episodes with this note on the manual search: "QI matches an alias for series with TVDB ID: 369316".
And the title says unknown scene number:
QI.S21E10.Upsadaisy.REPACK.1080p.iP.WEB-DL.AAC2.0.H.264-RNG
Scene Info
Title
QI
Release
21x10
TheTVDB
unknown
Unknown episode or series.
I can manually download a release and it correctly moves, renames, etc.
Is there a way to accept the alias as part of the series?
I read the FAQ and it mentions adding the series to thexem.info, but it’s not on there and registrations are closed.
Version 3.0.10.1567
Mono Version 6.12.0.182
Ubuntu 22.04.3 LTS
EDIT:
I forgot that I hadn’t updated to v4, so I just did that in case it works differently. New info:
Version 4.0.3.1413
.NET Yes (6.0.13)
Database Sqlite 3.37.2
Ubuntu 22.04.3 LTS
Hi,
I’m facing the same issue atm
Cardfight Vanguard overDress (400398) matches an alias for series with TVDB ID: 245821
Support here would be great! Thx!
The 2011 series actually contains the episodes for the 2019 series, given the 2019 series wasn’t added until September of 2023 it appears to be a duplicate that should be cleaned up by TheTVDB.
Best to contract their support and we can update if they decide that the 2019 series is a standalone series.
