I would like to know and understand what the logic of Sonarr is in the below scenario, if you can bear with me.
Talking about latest Windows Client, if I set up a profile with all available resolutions (because I don’t care right now about having the final res, I just want to have it and worry about final good quality later) and name it “Must-720” and set the final stop resolution (the resolution which when available will mean that there is no better resolution for this profile so it should stop looking) as a WEBDL720p, Sonarr will:
a) When WEBDL720p is available and any 1080p is available, it will get one (the best? biggest in byte?) 1080p, consider it better quality than anything lower and the WEBDL720 will be ignored (either by size comparison, or quality comparison).
b) When WEBDL720p is available and any 1080p is available, it will get the WEBDL720p as the final resolution desired by the profile.
c) When WEBDL720p is not available and any 1080p is available, it will download the 1080p and never look for the WEBDL720p
d) When WEBDL720p is not available and any 1080p is available, it will download the 1080p and still try to download the WebDL720p but the quality comparison reports the 1080 as “better” or “bigger” and the 720 is thrown out.
e) When WEBDL720p is not available and any 1080p is available, it will download the 1080p and still try to download the WebDL720p and when it finds it, it will replace the 1080p with the WEBDL720p as the final requested resolution.
f) When WEBDL720p is not available, nor is any 1080p or any 720p, it will download what it can find, and still be looking for the WEBDL720p only.
g) When WEBDL720p is not available, nor is any 1080p or any 720p, it will download what it can find, and still be looking for the WEBDL720p AND the 1080p or any higher resolution to the one it currently has.
Which of the above is true?
If partially true and not covered by any choice, please restate them in the correct way.
Finally, if the above-described profile has any caveats or problems not mentioned above, please do mention them.
Thank you.
