Another time same problem.
Today at my trackers upload The Good Place 3x04. But Sonarr not download it even though file for this episode does´t exist.
18-10-19 20:42:12.8|Debug|DownloadDecisionMaker|Processing release ‘The Good Place 3x04 Jeremy Bearimy [WEB-DL NF 1080p h264 Dual DD 5.1 Sub][GrupoHDS] [spanish]’ from ‘HD-SPAIN’
18-10-19 20:42:12.8|Debug|Parser|Parsing string ‘The Good Place 3x04 Jeremy Bearimy [WEB-DL NF 1080p h264 Dual DD 5.1 Sub][GrupoHDS] [spanish]’
18-10-19 20:42:12.8|Trace|Parser|^(?<title>.+?)(?:(?:-_\W)+S?(?<season>(?<!\d+)(?:\d{1,2})(?!\d+))(?:[ex]|\W[ex]|){1,2}(?<episode>\d{2,3}(?!\d+|(?:[ex]|\W[ex]||-){1,2}\d+))).+?(?:[.+?])(?!\)
18-10-19 20:42:12.8|Debug|Parser|Episode Parsed. The Good Place - S03E04
18-10-19 20:42:12.8|Debug|Parser|Language parsed: Spanish
18-10-19 20:42:12.8|Debug|QualityParser|Trying to parse quality for The Good Place 3x04 Jeremy Bearimy [WEB-DL NF 1080p h264 Dual DD 5.1 Sub][GrupoHDS] [spanish]
18-10-19 20:42:12.8|Debug|Parser|Quality parsed: WEBDL-1080p v1
18-10-19 20:42:12.8|Debug|Parser|Release Group parsed:
18-10-19 20:42:12.9|Debug|ParsingService|Using Scene to TVDB Mapping for: The Good Place - Scene: 3x04 - TVDB: 3x03
18-10-19 20:42:12.9|Debug|AcceptableSizeSpecification|Beginning size check for: The Good Place 3x04 Jeremy Bearimy [WEB-DL NF 1080p h264 Dual DD 5.1 Sub][GrupoHDS] [spanish]
18-10-19 20:42:12.9|Debug|AcceptableSizeSpecification|Item: The Good Place 3x04 Jeremy Bearimy [WEB-DL NF 1080p h264 Dual DD 5.1 Sub][GrupoHDS] [spanish], meets size constraints.
18-10-19 20:42:12.9|Debug|CutoffSpecification|Comparing file quality with report. Existing file is HDTV-1080p v1
18-10-19 20:42:12.9|Debug|CutoffSpecification|Cutoff already met, rejecting.
18-10-19 20:42:12.9|Trace|ConfigService|Using default config value for ‘maximumsize’ defaultValue:‘0’
18-10-19 20:42:12.9|Debug|MaximumSizeSpecification|Maximum size is not set.
18-10-19 20:42:12.9|Debug|LanguageSpecification|Checking if report meets language requirements. Spanish
18-10-19 20:42:12.9|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: The Good Place 3x04 Jeremy Bearimy [WEB-DL NF 1080p h264 Dual DD 5.1 Sub][GrupoHDS] [spanish]
18-10-19 20:42:12.9|Debug|ReleaseRestrictionsSpecification|[The Good Place 3x04 Jeremy Bearimy [WEB-DL NF 1080p h264 Dual DD 5.1 Sub][GrupoHDS] [spanish]] No restrictions apply, allowing
18-10-19 20:42:12.9|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. WEBDL-1080p v1
18-10-19 20:42:12.9|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
18-10-19 20:42:12.9|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
18-10-19 20:42:12.9|Debug|UpgradeDiskSpecification|Comparing file quality with report. Existing file is HDTV-1080p v1
18-10-19 20:42:12.9|Debug|DelaySpecification|Profile does not require a waiting period before download for Torrent.
18-10-19 20:42:12.9|Debug|HistorySpecification|Performing history status check on report
18-10-19 20:42:12.9|Debug|HistorySpecification|Checking current status of episode [6194] in history
18-10-19 20:42:12.9|Debug|MonitoredEpisodeSpecification|Only 0/1 episodes are monitored. skipping.
18-10-19 20:42:12.9|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Existing file meets cutoff: HDTV-720p, [Permanent] Episode is not monitored
18-10-19 20:42:12.9|Trace|DownloadDecisionMaker|Processing release 13/53
