Helix (2015) doesn’t appear in TVDB and doesn’t appear as an option when adding series to Sonarr. Helix (2014) appears in both but is a completely different show. The series would need to be added to TVDB. Instructions for doing so can be found at http://www.thetvdb.com/wiki/index.php/Category:Series
Sorry I missed the S02 when I replied. Helix (2014) and Helix (2015) are two completely different shows though.
Helix (2014) http://www.imdb.com/title/tt2758950/?ref_=nv_sr_1
Helix (2015) http://www.imdb.com/title/tt1764355/?ref_=nv_sr_2
The person releasing those episodes has the naming wrong (i.e. they should not have put 2015 in the title). Which basically makes it extra difficult for Sonarr to correctly identify it. If the person making those releases simply removed the 2015 then it wouldn’t be a problem. e.g.
HELIX S02E01 H 264 (WEB-DL) DD5.1 1080p NLSubs -Q o Q-
Helix S02E01 XViD DD5 1 NLSubs -Q o Q-
I have the same issue with some releases. It’s annoying but luckily other people release those shows with correct naming and those get picked up by Sonarr.
I can see why it won’t work. Unfortunately this is the only version that is still downloadable. I’ll just get this manually then.
Sonarr doesn’t/won’t support QoQ releases because they put the year the season aired in the title, not the year it started.
Can you please also look at this release
Scott & Baley S02E02 720p HDTV Nl subs
Sonar did not picked it up from spotweb but if i change it to
Scott and Baley S02E02 720p HDTV Nl subs
and put it in nzbget sonar recognize it well
id tvdb : 249128
Name tvdb : Scott & Baily
Baley is not the same name as Baily - this needs to be added to the the proper list: Scene Naming (TVDB Naming Conflicts)
Did this one even show up in manual search?
Did this one even show up in manual search? no it did not
Some other thing i just noticed
Sonar see it as : Scott & Bailey
Tvdb : Scott & Bailey, Scott & Baily and they both use the same id tvdb : 249128
Will added to the proper list
Thank You
