Sonarr version: 2.0.0.5163 (from Ubuntu package)
Mono: official Ubuntu repo: 5.12.0.226-0xamarin3+ubuntu1404b1
OS: Ubuntu 14.04.5 LTS
Relevant parts:
16-5-13 07:08:05.8|Trace|EventAggregator|ApplicationStartedEvent -> ReconfigureLogging
16-5-17 16:54:18.7|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4146
16-6-5 07:25:39.9|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4146
16-6-21 12:16:04.1|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4146
16-7-7 07:22:56.6|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4146
16-7-25 06:41:12.4|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4146
16-8-17 07:00:34.5|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4146
16-9-8 06:55:18.2|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4146
16-9-15 19:06:58.1|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4146
18-5-20 19:55:16.7|Debug|Api|[PUT] /api/config/host: 202.Accepted (90 ms)
18-5-20 19:55:16.7|Debug|Api|[GET] /api/health: 200.OK (0 ms)
18-5-20 19:55:16.7|Debug|Api|[GET] /api/health: 200.OK (1 ms)
18-5-20 19:55:23.2|Error|Transmission|Unable to connect to Transmission, please check your settings
[v2.0.0.5163] NzbDrone.Core.Download.Clients.DownloadClientUnavailableException: Unable to connect to Transmission, please check your settings ---> System.Net.WebException: Failed to read complete http response ---> System.Net.WebException: Error getting response stream (ReadAsync): ReceiveFailure Value cannot be null.
Parameter name: src ---> System.ArgumentNullException: Value cannot be null.
Parameter name: src
at System.Net.HttpWebRequest+<RunWithTimeoutWorker>d__244`1[T].MoveNext () [0x000ba] in <fc308f916aec4e4283e0c1d4b761760a>:0
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Net.WebResponseStream+<ReadAsync>d__48.MoveNext () [0x00253] in <fc308f916aec4e4283e0c1d4b761760a>:0
at System.Net.WebConnectionStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 count) [0x00077] in <fc308f916aec4e4283e0c1d4b761760a>:0
at NzbDrone.Common.Extensions.StreamExtensions.ToBytes (System.IO.Stream input) [0x0001c] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Extensions\StreamExtensions.cs:13
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x001dd] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:108
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x001e9] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:112
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x000b5] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\FallbackHttpDispatcher.cs:53
at NzbDrone.Common.Http.HttpClient.ExecuteRequest (NzbDrone.Common.Http.HttpRequest request) [0x0007e] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\HttpClient.cs:119
at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\HttpClient.cs:55
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.AuthenticateClient (NzbDrone.Common.Http.HttpRequestBuilder requestBuilder, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings, System.Boolean reauthenticate) [0x0004f] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:212
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.ProcessRequest (System.String action, System.Object arguments, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x0001f] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:249
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.ProcessRequest (System.String action, System.Object arguments, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00138] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:301
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetSessionVariables (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:145
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetConfig (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:119
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetClientVersion (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:109
at NzbDrone.Core.Download.Clients.Transmission.Transmission.ValidateVersion () [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\Transmission\Transmission.cs:28
at NzbDrone.Core.Download.Clients.Transmission.TransmissionBase.TestConnection () [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionBase.cs:194
18-5-20 19:55:23.2|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
-- Unable to connect
18-5-20 19:55:23.2|Debug|Api|[POST] /api/downloadclient/test: 400.BadRequest (26 ms)
Since today Sonarr doesn’t seem to be able to connect to Transmission. I haven’t updated Transmission, Mono or Sonarr. I seem to have the same issue in Radarr (the same error), but other tools that use the Transmission API do work. Transmission itself doesn’t seem to have any issues as far as I can see, downloads work fine.
Any tips on where to start looking for a cause?
