Mono version (if Sonarr is not running on Windows): 5.12.0.226
OS: Ubuntu 16.04
Debug logs: https://pastebin.com/Qe8W10D2
Description of issue: Sonarr is unable to connect to transmission after I updated mono. I was trying to fix an issue with radarr not taking an update and wound up breaking both sonar and radarr after updating to the latest version of mono. Do I have to downgrade or is there a workaround?
Edit, it connects fine without the reverse proxy which doesn’t make sense to me. Whatever it works for now I’ll have to dig into the network logs later.
