Sonarr version (exact version): 2.0.0.5344 - 13/03/2020 Mono version (if Sonarr is not running on Windows): 5.20.1.34-16 OS: Synology NAS
Dear All
I’m new to Sonarr, and I am lost in the parameters.
I use a Synology DS918+ for Sonarr, and a Useed Box to download.
Now, Sonarr can find the torrents, and downloads them on Useed, by the process stops afterward, I have now download from USeed to ny NAS, and of course no renaming.
If this topic has already been explained, sorry, I did not find it.
im presuming that useed is some sort of external download client service, not something local to your nas or network.
you probably need a remote path mapping so sonarr can tell where the useed path really is located
the logs should show what the path useed is giving back for the completed job, you just need the remote path mapping to convert that path into something sonarr can use to actually access it.
I have found in the logs some more information:
Couldn’t process tracked download Your.Honor.S01E09.1080p.WEB.H264-GGEZ[rarbg]: Access to the path ‘/etc/postgresql’ is denied.
What I understood is that “Remote path” is the path on the USeed box
and local path is the one on the NAS
that seems to indicate that whatever account sonarr is running as cant access that local path. youll need to check the permissions to confirm it can.
yes, you convert part of the remote path to a local path that sonarr can see and access.
that old thread says that useed will work with webdav. you may need to wait for someone with more knowledge of that side of things as ive never used it.
you may also want to check if useed has any doco on working with sonarr
its probably also a good idea to set the log level to debug, then leave it for a while and upload all the debug logs (zipped) somewhere t.hey can be accessed online so we can see whats going on. theyre going to be needed at some point
is it the sonarr package from the synocommunity site?
its v2 on dsm so i think there is a start file somewhere (possibly under @appdata, sorry i havent used that version for a long time) and it has an entry for it, it used to be user=sonarr - the syno community site may have instructions on where it is and how to change it.
i used to change it to admin (as i had no external access to it so wasnt too fussed about security back then) so maybe check if you have a user named sonarr in dsm? if you do you can make it an admin to see if that fixes the issue.
it sounds familiar but as i said, i havent used v2 (or the syno community version) for a long time. i use docker and the linuxserver/sonarr image
check if sc-download is a member of the administrators group, (dsm > control panel > group) and if not temporarily add it in there and see if that helps
if you have SSH enabled then maybe log in and check if /etc/postgresql exists. i checked mine and it doesnt exist in my DSM, or the docker container. its possible that path is for useed and theres an issue on their end?
I also had Sonarr deleting all the subtitles from TV Show.
So I gave up, and uninstalled it.
Too complicated for someone that does not know
Anyway, thank you rhom for you supprot.
