My apologies, i saw related post but i did not understand how to solve my problem. I added two download clients, one locally and one from my seedbox but i don’t understand how to retrieve torrents from my seedbed like i do locally.
The parameters are :
Host : seedbox address
Port : 443
User & password
I did no change the URL base, which is : /transmission/
I guess that the solution is in Remote Path Mapping but i don’t know Remote Path, so i use the following parameters :
4. Host : seedbox address
5. Remote path //SB//SB1293//torrent/ - Found in an error message
6. Local Path : the local download folder
The last error message says : “Import failed, path does not exist or is not accessible by Sonarr: /Volumes/Mac Mini HD/Users/myname/Downloads/Torrents/MD.S02E131080p5.1WEBRipX265HEVCD0ct0rLewUTR.mkv.mkv.mkv”
You need to mount that path locally, so its accessible to Sonarr like any other folder on your system. If you mounted it to /mnt/seedbox you would set /mnt/seedbox as the path.
Never used it myself, if you pop into our IRC channel someone might be able to suggest how to use it, not sure if there is another thread on the forums with a how to.
As long as it can be mounted to a local path and allows Sonarr to check the size and get the runtime information (through MediaInfo), it should be fine.
Looks like it’s correct as Sonarr is trying to import it, but that is failing, possibly something with the WebDAV connection, though the issue could be with the destination of the import.
Is there a way to check the issue ? Indeed, regarding Path mapping i put “//SB/SB1293/torrent/” because i founded in an error message but initially i was thinking about “hector.useed.fr”.
The message :
Import failed, path does not exist or is not accessible by Sonarr: //SB//SB1293//torrent/once.upon.a.time.s05e21.1080p.web.dl.6ch.hevc.x265.rmteam.mkv
Okay, that confirms that the WebDAV connection is working. Now we need to test whether the issue in Sonarr is with the source file or the destination file.
In the case of:
[v2.0.0.3953] System.IO.IOException: Invalid handle to path "/Volumes/webdav/[ www.CpasBien.cm ] The.100.S03E08.FASTSUB.VOSTFR.720p.HDTV.x264-ZT.mkv" or "/Volumes/Series/Series/The 100/Season 3/The 100 - S03E08 - Terms and Conditions HDTV-720p.mkv.partial~"
Copy the file from /Volumes/webdav/[ www.CpasBien.cm ] The.100.S03E08.FASTSUB.VOSTFR.720p.HDTV.x264-ZT.mkv to another local path (not the the TV folder, but another location for testing), then update the Remote Path Mapping to the new location, if you copied the file to /Volumes/Macintosh HD/Test use that path, then let Sonarr try to import the file.
16-5-15 13:21:55.0|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: /Volumes/Mac Mini HD/Volumes/Mac Mini HD/Users/antoinebachelay/Downloads/Torrents/Sonarr/Gotham.S02E16.1080p.WEB-DL.DD5.1.H264-NTb[rarbg]
Duplicated folder names in the path, its either that or permissions.
