Sonarr version (exact version): 3.0.1.418
Mono version (if Sonarr is not running on Windows): 5.18.1.0
OS: Ubuntu 16.04.6
Debug logs
19-4-1 14:57:37.4|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- Either 'Categories' or 'Anime Categories' must be provided
19-4-1 15:02:11.7|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- Folder is not writable by user sonarr
19-4-1 15:02:56.5|Warn|SonarrErrorPipeline|Invalid request Validation failed:
19-4-1 15:03:00.4|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- Invalid Path
-- Invalid Path
19-4-1 15:03:11.4|Warn|SonarrErrorPipeline|Invalid request Validation failed:
19-4-1 15:03:47.2|Warn|SonarrErrorPipeline|Invalid request Validation failed:
19-4-1 15:03:58.6|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- Invalid Path
-- Invalid Path
19-4-1 15:04:17.2|Info|RssSyncService|Starting RSS Sync
19-4-1 15:04:17.6|Info|DownloadDecisionMaker|Processing 50 releases
19-4-1 15:04:17.8|Info|RssSyncService|RSS Sync Completed. Reports found: 50, Reports grabbed: 0
19-4-1 15:05:19.2|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- 'Host' should not be empty.
-- 'Remote Path' should not be empty.
19-4-1 15:07:07.1|Warn|SonarrErrorPipeline|Invalid request Validation failed:
19-4-1 15:07:18.7|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- Invalid Path
-- Invalid Path
19-4-1 15:08:08.1|Warn|SonarrErrorPipeline|Invalid request Validation failed:
19-4-1 15:17:03.9|Info|LifecycleService|Restart requested.
19-4-1 15:17:05.0|Info|Bootstrap|Starting Sonarr - /usr/lib/sonarr/bin/Sonarr.exe - Version 3.0.1.418
19-4-1 15:17:05.8|Info|AppFolderInfo|Data directory is being overridden to [/var/lib/sonarr]
19-4-1 15:17:08.0|Info|Router|Application mode: Interactive
19-4-1 15:17:08.1|Info|MigrationLogger|*** Migrating data source=/var/lib/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
19-4-1 15:17:08.3|Info|MigrationLogger|*** Migrating data source=/var/lib/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
19-4-1 15:17:08.4|Info|OwinHostController|Listening on the following URLs:
19-4-1 15:17:08.4|Info|OwinHostController| http://*:8989/
19-4-1 15:17:08.5|Info|SonarrBootstrapper|Starting Web Server
19-4-1 15:17:35.5|Warn|SonarrErrorPipeline|Invalid request Validation failed:
19-4-1 15:17:39.0|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- Invalid Path
-- Invalid Path
19-4-1 15:17:46.5|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- Invalid Path
19-4-1 15:17:54.7|Warn|SonarrErrorPipeline|Invalid request Validation failed:
19-4-1 15:18:05.8|Warn|SonarrErrorPipeline|Invalid request Validation failed:
19-4-1 15:19:40.0|Info|RssSyncService|Starting RSS Sync
19-4-1 15:19:41.4|Info|DownloadDecisionMaker|Processing 50 releases
19-4-1 15:19:41.6|Info|RssSyncService|RSS Sync Completed. Reports found: 50, Reports grabbed: 0
19-4-1 15:30:23.7|Info|Bootstrap|Starting Sonarr - /usr/lib/sonarr/bin/Sonarr.exe - Version 3.0.1.418
19-4-1 15:30:25.9|Info|AppFolderInfo|Data directory is being overridden to [/var/lib/sonarr]
19-4-1 15:30:26.6|Info|Router|Application mode: Interactive
19-4-1 15:31:44.8|Info|Bootstrap|Starting Sonarr - /usr/lib/sonarr/bin/Sonarr.exe - Version 3.0.1.418
19-4-1 15:31:47.4|Info|AppFolderInfo|Data directory is being overridden to [/var/lib/sonarr]
19-4-1 15:31:47.8|Info|Router|Application mode: Interactive
19-4-1 15:31:48.5|Info|MigrationLogger|*** Migrating data source=/var/lib/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
19-4-1 15:31:49.6|Info|MigrationLogger|*** Migrating data source=/var/lib/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
19-4-1 15:31:49.7|Info|OwinHostController|Listening on the following URLs:
19-4-1 15:31:49.7|Info|OwinHostController| http://*:8989/
19-4-1 15:31:50.8|Info|SonarrBootstrapper|Starting Web Server
19-4-1 15:33:12.8|Warn|SonarrErrorPipeline|Invalid request Validation failed:
19-4-1 15:33:16.9|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- Invalid Path
-- Invalid Path
I just did a fresh install, and when I try to add a TV show and ass the path, no matter what I do, after browsing the path and selecting, the root folder selector never fills with what I selected and I invariably get the error that I have chosen an invalid path. Any ideas?
