Same scenario. Stopped Sickbeard. Started Sonarr. It ran for a few minutes before stopping.
Basically the same closing lines in the log- which was swelling fast.
15-7-28 15:47:01.1|Debug|Parser|Quality parsed: DVD v1
15-7-28 15:47:01.1|Debug|Parser|Release Group parsed: SNOW
15-7-28 15:47:46.2|Info|Bootstrap|Starting Sonarr - /usr/local/Sonarr/NzbDrone.exe - Version 2.0.0.3357
15-7-28 15:47:46.9|Info|MigrationLogger|*** Migrating data source=/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
15-7-28 15:47:47.3|Debug|MigrationLogger|Took: 00:00:00.3633071
15-7-28 15:47:47.3|Info|MigrationLogger|*** Migrating data source=/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
15-7-28 15:47:47.3|Debug|MigrationLogger|Took: 00:00:00.0218869
15-7-28 15:47:47.4|Info|Router|Application mode: Help
15-7-28 15:47:47.5|Info|ConsoleApp|Exiting main.
Figuring this might not be helpful, I looked on up in the log and noticed a segment which WASN’T formatted the same- no time/date stamp. Hope this helps…I included a few lines before/after for context. Thanks for the continued attention.
15-7-28 15:46:55.6|Debug|DiskScanService|Scanning '/mnt/user/TV/The Cell' for video files
15-7-28 15:46:55.7|Trace|Parser|^(?<title>.+?)(?:(?:[-_\W](?<![()\[!]))+S?(?<season>(?<!\d+)(?:\d{1,2}|\d{4})(?!\d+))(?:[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+))(?:(?:\-|[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+)))*)\W?(?!\\)
15-7-28 15:46:55.7|Debug|GlobalExceptionHandlers|Minor Fail: An exception was thrown by the type initializer for System.Drawing.GDIPlus
System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus ---> System.DllNotFoundException: libgdiplus.so
at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x00000] in <filename unknown>:0
at System.Drawing.Image.InitFromStream (System.IO.Stream stream) [0x00000] in <filename unknown>:0
at System.Drawing.Bitmap..ctor (System.IO.Stream stream, Boolean useIcm) [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Bitmap:.ctor (System.IO.Stream,bool)
at ImageResizer.ImageBuilder.DecodeStream (System.IO.Stream s, ImageResizer.ResizeSettings settings, System.String optionalPath) [0x00000] in <filename unknown>:0
at ImageResizer.ImageBuilder.LoadImage (System.Object source, ImageResizer.ResizeSettings settings, Boolean restoreStreamPos) [0x00000] in <filename unknown>:0
15-7-28 15:46:55.7|Debug|Parser|Episode Parsed. Supernatural - S04E15
15-7-28 15:46:55.7|Debug|DiskScanService|3 video files were found in /mnt/user/TV/The Cell
15-7-28 15:46:55.7|Debug|Parser|Language parsed: English
15-7-28 15:46:55.7|Trace|EventAggregator|MediaCoversUpdatedEvent <- MetadataService
15-7-28 15:46:55.7|Trace|DiskScanService|Finished getting episode files for: [109171][The Cell] [00:00:00.0185403]
15-7-28 15:46:55.7|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Supernatural.S04E15.Death.Takes.A.Holiday.BDRip.XviD-SAiNTS
15-7-28 15:46:55.7|Trace|EventAggregator|MediaCoversUpdatedEvent -> SeriesModule
15-7-28 15:46:55.7|Debug|DiskScanService|[109171][The Cell] Cleaning up media files in DB
15-7-28 15:46:55.7|Debug|Parser|Quality parsed: DVD v1
15-7-28 15:46:55.7|Debug|Parser|Release Group parsed: SAiNTS
15-7-28 15:46:55.7|Debug|ImportDecisionMaker|Analyzing 0/3 files.
