The standard command to run Sonarr from the unraid console would be:
sudo -Hu nobody /bin/bash -c '. ‘/usr/local/PhAzE-Common/Sonarr/startcfg.sh; mono-service -d:/usr/local/Sonarr -l:/var/run/Sonarr/Sonarr.pid /usr/local/Sonarr/Nzbdrone.exe &’
Now, you would need to change the install directory to point to wherever it is actually installed (so replace /usr/local/Sonarr with the path).
To get the trace, you would need to use the following from the unraid console:
sudo -Hu nobody /bin/bash -c '. ‘/usr/local/PhAzE-Common/Sonarr/startcfg.sh; MONO_LOG_LEVEL=“debug” MONO_LOG_MASK=“dll” mono /usr/local/Sonarr/NzbDrone.exe’ > /Sonarr_trace.log
I’m not sure if Markus wants to change the mono mask or anything, but using the above (stil updating the /usr/local/Sonarr with the proper install path) should give you the output to a file in the root called Sonarr_trace.log.
Once running, use the app like normal, and press CRTL-C on the unraid console to exit the app when done.
