Sonarr version : 2.0.0.5252
Mono version :5.18.0.240
OS: UnRAID (Docker)
Debug logs: I have turned on debug logging and am waiting for the issue to re-appear.
At seemingly random intervals (starting around a week ago) the “Check For Finished Downloads” task appears to get stuck and will not import any finished downloads until I restart Sonarr. This setup has been working flawlessly for years and I can’t recall changing anything in Sonarr or how my downloads are handled anytime recently that might explain the sudden change.
I know the task is stuck as the graphic is spinning and the last execution will be hours or days since the last run (this morning it was 3 hours, yesterday it had been stuck for about 15 hours). I can see that the download reports are being sent to my downloaders (these show up in the Activity History) and that the label/category is set correctly when I go back and check NZBGet/RTorrent.
Restarting Sonarr continues the import and fixes whatever the issue is temporarily. So Sonarr knows it has episodes to import (as I do not have to manually import any missed episodes, so it is tracking the releases properly), it just seems to get stuck for some reason and hangs there.
There does not appear to be a correlation between a specific show or episode. So far I have had it happen on several single episodes of Dororo & Mob Psycho 100, The Late show with Stephen Colbert, True Detective, and a few others I can’t recall.
EDIT: Found this thread with similar issue, I checked and while I did have some Connections setup in Sonarr they are all old and long disabled. To be thorough I have removed them all together.
EDIT2: Issue seems to be gone now, still no idea what caused it but at least it is fixed.
