the problem is back again, i think the error above was a red herring…
this is what im seeing today…
some of the downloaded shows have been copied to the media folders but with an old date modified, others have not been copied. All torrents regardless remain in the utorrent queue, and sonnarr ui shows no entries under ‘activity’.
Those shows which remain uncopied to media folders have no corresponding error in logs…
Those shows which have been copied to media folders have this error below…
Note- The date stamp in the log does not match the datestamp of the sonnarr host pc but do match the date stamps of the shows successfully copied to media folders…
15-5-25 20:24:43.3|Warn|ImportApprovedEpisodes|Couldn't import episode D:\Downloaded\showname.S04E07.HDTV.x264-ASAP[ettv]\showname.S04E07.HDTV.x264-ASAP.mp4
System.IO.IOException: The file exists.
at System.IO.__Error.WinIOError()
at System.IO.File.Move(String sourceFileName, String destFileName)
at NzbDrone.Common.Disk.DiskProviderBase.TransferFile(String source, String destination, TransferMode mode, Boolean overwrite) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskProviderBase.cs:line 285
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.TransferFile(EpisodeFile episodeFile, Series series, List`1 episodes, String destinationFilename, TransferMode mode) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 126
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.MoveEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 66
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode, Boolean copyOnly) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:line 64
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import(List`1 decisions, Boolean newDownload, DownloadClientItem downloadClientItem) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:line 89
