Hi guys,
I’ve got sonarr set up and it works really well with NZB’s.
With torrents however, sonarr shows 100% completed but does not copy the file over to my TV Shows directory. I’m using sonarr with transmission as the client, and I can see the download is complete and in the default transmission directory. I have set Completed Download Handling
both Enable
and Remove
to YES, and Failed Download Handling
both Redownload
and Remove
to YES.
There is nothing in the logs mentioning that the download has been completed, only information about the snatching.
16-1-8 22:02:08.3|Info|DownloadService|Report sent to Transmission. XXXX
Anything I should check?
Thanks!
