Sonarr version (exact version): 2.0.0.4146
Download client: Deluge 1.3.12
Mono version (if Sonarr is not running on Windows): n/a?
OS: Win 10 Pro
((Debug logs)) (posted to hastebin or similar): http://hastebin.com/cosutawici.tex (cut due to length restrictions)
First off - forgive me if this has been answered before. I’ve seen a few posts of this nature (eg, here, here, and here), but haven’t come across a solution yet. Now to the issue:
Sonarr doesn’t seem to be copying new TV episodes from the downloaded directory to their show/season directory. It sees the torrents, sees that they are at 100%, but doesn’t do anything with the files. If I set a drone directory, it nabs all the episodes, renames them, and sticks them in their proper folder, but that of course means I can no longer seed.
I have browsed the logs a bit, but can’t find any damning info. The torrents appear to be parsed - their filenames are decoded, quality is correctly detected, etc., but there doesn’t seem to be any copying or failures related to file processing.
Some additional troubleshooting, and responses to the links I posted above:
It’s my understanding that sonarr’s default behavior is to copy, not move, if hardlinks is disabled. Also according to sonarr’s documentation, hardlinks are finicky and may prevent renaming. I did try enabling hardlinks but nothing happened (are hardlinks even possible on Windows?).
The drone folder scraping works fine, so I’m guessing permissions are fine. Still, my user has full control over the downloads and TV folders.
Rebooting a dozen times didn’t help
One last thing I noticed - after changing my downloader settings (namely changing/removing a label), sonarr no longer shows the episode as being at 100%, and simply says it is missing from disk. Not sure if it just takes a few minutes for it to re-scan or if there’s some other issue…
So anyhow, I’m a bit stuck right now. Is there anybody out there that may have come across this issue or know what I can do to gather up some more info? Thank you all!!
