Sonarr version: 2.0.0.5338 OS: OSX 10.15.1 of Catalina Debug logs: N/A Description of issue:
Hi hive mind, my old 2013 MBP auto updated to Catalina. Within Sonarr, I can see on-disk folders but i am unable to see anything on my mounted drives. Yes the drives are mounted, the files and folders are visible in Finder. The problem lies in the visibility within Sonarr and Radarr. Any thoughts? Thanks.
Not sure I understand, but I’d like to. Is this being discussed somewhere else? (I don’t see a developer commenting on the other thread that you referenced here…)
Update: Just did a whole bunch of reading and now i am unable to open Sonarr after some suggestions. The permissions is not working properly in Catalina, there seems to be some gaps. It works with SABnzbd with the “Network” volume.
The forums say to use the windows EXE in Catalina as a work around. Good luck. i am going to have to find a different avenue.
