Sonarr has a problem with the Heartland series and I think it’s because of the naming at The TVDB site (or whatever site Sonarr uses). In “add series” if you search for Heartland 2007, there will be 2 results - Heartland (2007) and Heartland (2007) (CA).
I add - Heartland (2007) (CA) but Sonarr doesn’t add any folders for it. So I manually create it - E:\TV Shows\Heartland and add the path in the series EDIT page. From here, I set Sonarr to watch season 1. It refreshes but doesn’t find any episodes.
I manually downloaded Season 1 and added it to the Drone Factory folder. Sonarr ignored it. So I dropped it into Sab’s watched folder and waited for the downloads to complete. Sonarr again ignores the files.
So I renamed them manually (Heartland S03E01…) in the Drone Factory folder and selected “Manual Import”. It scanned and listed all the files but came back with an error - Import Rejected: Unknown Series.
Why doesn’t it see that it’s a Heartland series when it’s clearly named that way? Why wasn’t Sonarr initially able to create a folder for this series? (I can add any other series without a problem). Drone Factory works as expected except for this series.
