Sonarr version (exact version): 2.0.0.4645
Mono version (if Sonarr is not running on Windows): 4.8.0.520/8f6d0f6
OS: Ubuntu 16.10
((Debug logs))
Normal log
Debug log
Trace log
Great application - when I’ve got it to work, it’s been fantastic, however, I’ve had a few problems, the latest of which I haven’t been able to solve via the forums or Google.
Essentially my current issue is that shortly after starting up Sonarr, the application hangs.
This has not always been the case, but it seems to be doing it every time now.
I upgraded NzbDrone and Mono to the latest versions today, but the problem still occurs.
The drive where the files are downloaded by uTorrent is a local drive, but the drive where the files are imported to by Sonarr is a network drive (MyBookLive) which is mounted using cifs - not sure if this is relevant as it seemed to work alright in the past, but thought it worth mentioning.
If I kill the mono process, it becomes defunct and I end up having to restart the machine in order to be able to start Sonarr again (the machine doesn’t want to shut down cleanly after Sonarr hangs either…).
Hoping there is something in the debug/trace logs which gives an indication of the problem?
Thanks
-Stu
