Shows not being automatically grabbed
I’m running Sonarr with NZBGet on Ubuntu and having strange behaviour.
Left to it’s own devices, Sonarr is not grabbing new episodes of shows, despite them being listed in the calendar.
If I go to one of these episodes (after it’s aired) and select either Automatic or Manual search it will send it to NZBGet and download it, it just won’t do it on it’s own.
Also, once an episode has been downloaded, despite NZBGet reporting that the episode was successfully handled by NZBToDrone and the episode being added to the history, it isn’t being moved from the download folder. The only way to force this is to manually restart Sonarr, and then it will move the episode into the correct folder.
Any help / advice gratefully received!
Thanks!
Is RSS enabled in your indexer settings in Sonarr?
Is the RSS Sync interval set to a value above zero (15 is the default)?
Sonarr’s history?
There is nothing in Sonarr that would move it on startup, so I don’t see how this is possible. Please pastebin some ((debug logs)) of the import process so we can take a look.
Why are you using nzbToDrone? If you use Sonarr’s built-in importing (Completed Download Handling) it should handle everything without a script.
Thanks for the reply!
Yes, and yes it’s set to 15.
No, NZBGet’s history. There is nothing in Sonarr’s history (in the Web UI).
[quote=“markus101, post:2, topic:4667”]
There is nothing in Sonarr that would move it on startup, so I don’t see how this is possible. [/quote]
It’s like it’s hung and restarting it ‘wakes’ it up.
No problem, what would you like to see, specifically? I have over 18MB of logs for the last 24 hours, during which time it missed downloading 5 episodes!
Isn’t nzbToDrone more efficient than periodically scanning the download folder?
Anyway, that’s the secondary issue; if the episodes are not being grabbed and passed to NZBGet, there’s nothing to look for in the first place!
Further info:
If I click the RSS Sync button on the Series page, it searches for and grabs the missing episodes, it just won’t do it automatically.
Also, I have a lot of shows in the library, many of which are complete and set to Unmonitored, but it still seems to be refreshing them on a regular basis.
The downloads are still not moving across, so I’ve implemented the Drone Factory setting on the download folder, but that’s not working either.
Logs:
15-3-17 11:31:43.0|Debug|DownloadedEpisodesCommandService|External directory scan request for known download 17ae4d97e8c64181a6b420bbe27fbbf7. [/home/maxnutter/Downloads/complete/Castle.2009.S07E17.HDTV.x264-LOL]
15-3-17 11:31:43.0|Debug|Parser|Parsing string 'Castle.2009.S07E17.HDTV.x264-LOL'
15-3-17 11:31:43.0|Trace|Parser|^(?<title>.+?)(?:(?:[_\W](?<![(\[]))+S?(?<season>(?<!\d+)(?:\d{1,2}|\d{4})(?!\d+))(?:[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+))(?:(?:\-|[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+)))*)\W?(?!\\)
15-3-17 11:31:43.0|Debug|Parser|Episode Parsed. castle2009 - S07E17
15-3-17 11:31:43.0|Debug|Parser|Language parsed: English
15-3-17 11:31:43.0|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Castle.2009.S07E17.HDTV.x264-LOL
15-3-17 11:31:43.0|Debug|Parser|Quality parsed: SDTV v1
15-3-17 11:31:43.0|Debug|Parser|Release Group parsed: LOL
15-3-17 11:31:43.0|Debug|DownloadedEpisodesImportService|Castle.2009.S07E17.HDTV.x264-LOL folder quality: SDTV v1
15-3-17 11:31:43.0|Debug|DiskScanService|Scanning '/home/maxnutter/Downloads/complete/Castle.2009.S07E17.HDTV.x264-LOL' for video files
15-3-17 11:31:43.0|Debug|DiskScanService|2 video files were found in /home/maxnutter/Downloads/complete/Castle.2009.S07E17.HDTV.x264-LOL
15-3-17 11:31:43.2|Debug|ImportDecisionMaker|Analyzing 2/2 files.
15-3-17 11:31:43.2|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for /home/maxnutter/Downloads/complete/Castle.2009.S07E17.HDTV.x264-LOL/castle.2009.717.hdtv-lol.mp4
15-3-17 11:33:43.3|Trace|ConfigService|Unable to find config key 'downloadedepisodesfolder' defaultValue:''
15-3-17 11:33:43.3|Trace|ConfigService|Unable to find config key 'autoredownloadfailed' defaultValue:'True'
15-3-17 11:33:43.3|Trace|ConfigService|Unable to find config key 'removefaileddownloads' defaultValue:'True'
15-3-17 11:33:43.3|Trace|ConfigService|Unable to find config key 'downloadclientworkingfolders' defaultValue:'_UNPACK_|_FAILED_'
15-3-17 11:33:58.4|Debug|RootFolderService|Generating list of unmapped folders
15-3-17 11:33:58.6|Debug|RootFolderService|0 unmapped folders detected.
15-3-17 11:33:58.6|Debug|RootFolderService|Generating list of unmapped folders
15-3-17 11:33:58.7|Debug|RootFolderService|0 unmapped folders detected.
Also, Sonarr’s activity queue is still reporting the episodes as downloading long after they’ve finished and been added to NZBGet’s history.
Which indexer(s) are you using? I’m aware of two having issues with RSS feeds (that would cause Sonarr to miss episodes), they are Dog and Oz, both due to load issues on their API servers.
Thats not how Completed Download Handling works, it talks to nzbget’s API, figures out what has been completed and imports that.
Sonarr is trying to import files that are there, the logs don’t show why it was rejected for import (2 minute gap in the logs), if that fiules is already imported its likely because its not an upgrade.
Don’t mix CDH and Drone factory, if you want to try to process files that aren’t importing setup Drone Factory on a separate folder and drop files there.
Logs of an RSS sync and one of something failing to import, likely two separate logs.
Thanks.
I’m using NZBPlanet.
So I should ditch any post-processing on the NZBGet side (nzbToDrone) and just let Sonarr find it?
Okay, I’ll ditch that, thanks.
I’ll see what I can find.
Any idea why it seems to be still searching through unmonitored shows? I have a feeling that is why the RSS is going screwy?
Unless you’re doing something special in the post processing, we recommend using CDH, so yes.
RSS processes whatever is on the RSS feed, then it will determine what is required, there will be lots of things you don’t need or don’t want, but its normal.
Definitely worth setting up a second indexer as well, Womble’s might work well as a start, but there are other free ones as well.
15-3-17 11:26:58.2|Debug|Parser|Parsing string 'Castle.2009.S07E17.HDTV.x264-LOL'
15-3-17 11:26:58.2|Trace|Parser|^(?<title>.+?)(?:(?:[_\W](?<![(\[]))+S?(?<season>(?<!\d+)(?:\d{1,2}|\d{4})(?!\d+))(?:[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+))(?:(?:\-|[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+)))*)\W?(?!\\)
15-3-17 11:26:58.2|Debug|Parser|Episode Parsed. castle2009 - S07E17
15-3-17 11:26:58.2|Debug|Parser|Language parsed: English
15-3-17 11:26:58.2|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Castle.2009.S07E17.HDTV.x264-LOL
15-3-17 11:26:58.2|Debug|Parser|Quality parsed: SDTV v1
15-3-17 11:26:58.2|Debug|Parser|Release Group parsed: LOL
15-3-17 11:26:58.2|Debug|AcceptableSizeSpecification|Beginning size check for: Castle.2009.S07E17.HDTV.x264-LOL
15-3-17 11:26:58.2|Debug|AcceptableSizeSpecification|Item: Castle.2009.S07E17.HDTV.x264-LOL, meets size constraints.
15-3-17 11:26:58.2|Debug|LanguageSpecification|Checking if report meets language requirements. English
15-3-17 11:26:58.2|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: Castle.2009.S07E17.HDTV.x264-LOL
15-3-17 11:26:58.2|Debug|ReleaseRestrictionsSpecification|[Castle.2009.S07E17.HDTV.x264-LOL] No restrictions apply, allowing
15-3-17 11:26:58.2|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. SDTV v1
15-3-17 11:26:58.2|Trace|ConfigService|Unable to find config key 'minimumage' defaultValue:'0'
15-3-17 11:26:58.2|Debug|MinimumAgeSpecification|Minimum age is not set.
15-3-17 11:26:58.2|Trace|ConfigService|Unable to find config key 'retention' defaultValue:'0'
15-3-17 11:26:58.2|Debug|RetentionSpecification|Checking if report meets retention requirements. 0
15-3-17 11:26:58.2|Debug|DelaySpecification|Profile does not require a waiting period before download for Usenet.
15-3-17 11:26:58.3|Trace|DownloadDecisionMaker|Processing report 70/100
15-3-17 11:26:58.3|Trace|EventAggregator|Publishing CommandUpdatedEvent
15-3-17 11:26:58.3|Trace|EventAggregator|CommandUpdatedEvent -> CommandModule
15-3-17 11:26:58.3|Trace|EventAggregator|CommandUpdatedEvent <- CommandModule
Okay, thanks.
I’ve added Womble’s and ditched nzbToDrone, so will see what happens when the next episodes are available (overnight tonight).
Nothing happened overnight, nothing in the logs either!
I’ve now hit the RSS Sync button and it has found everything.
Also noticed that for some reason the logs have entries for nzbToMylar, which is odd!
Logs are also full of stuff like this:
15-3-17 14:56:08.2|Debug|Parser|Quality parsed: Unknown v1
15-3-17 14:56:08.2|Debug|Parser|Release Group parsed:
15-3-17 14:56:08.2|Debug|Parser|Parsing string 'Raising Hope - 4x21 - How I Met Your Mullet.tbn'
15-3-17 14:56:08.2|Trace|Parser|^(?<title>.+?)(?:(?:[_\W](?<![(\[]))+S?(?<season>(?<!\d+)(?:\d{1,2}|\d{4})(?!\d+))(?:[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+))(?:(?:\-|[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+)))*)\W?(?!\\)
15-3-17 14:56:08.2|Debug|Parser|Episode Parsed. raisinghope - S04E21
15-3-17 14:56:08.2|Debug|Parser|Language parsed: English
for shows that are downloaded, complete and marked as unmonitored.
Now the shows have downloaded, they are still sat in Sonarr’s Activity queue, reporting as downloading.
Unfortunately, I think nzbToDrone has still run; I’m having a little trouble unhooking it!
Edit: Stopped and restarted the NZBDrone service and now all the downloaded episodes have been imported.
Absolutely nothing? Or no RSS Syncs?
No RSS sync.
System -> Tasks will show the last time RSS Sync was run, but it only wouldn’t run if RSS Sync is disabled (interval 0), since manually running it works, I don’t think the issue is RSS Sync being disabled on each indexer, but you can double check.
Name            Interval	Last Execution	Next Execution
Rss Sync	16 minutes	a day ago	now
The Activity queue (all of which have downloaded):
Series	Episode	Episode Title	Quality	Protocol	Timeleft	Progress
Undateable (2014) 	1x02 Pants Buddies	SDTV  nzb    00:00:03
Undateable (2014) 	1x03 Three's A Crowd	SDTV  nzb  00:00:58
Undateable (2014) 	1x04 The Switch	SDTV 	nzb 	00:01:55
Last few log entries:
15-3-18 17:47:24.0|Debug|RootFolderService|0 unmapped folders detected.
15-3-18 17:47:24.0|Debug|RootFolderService|Generating list of unmapped folders
15-3-18 17:47:24.2|Debug|RootFolderService|0 unmapped folders detected.
15-3-19 09:32:30.9|Trace|ConfigService|Unable to find config key 'shortdateformat' defaultValue:'MMM D YYYY'
15-3-19 09:32:31.0|Trace|ConfigService|Unable to find config key 'longdateformat' defaultValue:'dddd, MMMM D YYYY'
15-3-19 09:32:31.0|Trace|ConfigService|Unable to find config key 'timeformat' defaultValue:'h(:mm)a'
15-3-19 09:32:31.0|Trace|ConfigService|Unable to find config key 'showrelativedates' defaultValue:'True'
Last night’s episodes were not sent to NZBGet either.
Tasks:
Application Update            6 hours        a day ago        now
Backup                        7 days        17 days ago        now
Check For Finished Download    1 minute    a day ago        now
Check Health                6 hours        a day ago        now
Downloaded Episodes Scan    1 hour        6 days ago        now
Housekeeping                1 day        16 days ago        now
Refresh Series                12 hours    15 days ago        now
Tracked Cleanup                1 minute    a day ago        now
Trim Log                    1 hour        a day ago        now
Update Scene Mapping        3 hours        a day ago        now
Of all of these, Refresh Series appears to be constantly running. All the time.
I should have asked this from the beginning:
Which version of Sonarr?
Which version of mono?
Sonarr Version
2.0.0.3004
Mono Version
3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014)
Every job hasn’t run in multiple cycles.
Please restart Sonarr and pastebin some trace logs when the jobs stop running again.
I’ve just restarted, and there’s already over 6MB of logs!!
Anything you want specifically, as Pastebin only takes 512k!
I want the logs when it stops running jobs (hangs), so we can see what is causing it to hang.
