Remove prepended / appended text strings from releasename in post processing
Hello,
love using Sonarr with the torrent option.
I have one feature request for post processing.
From time to time I download a release that will have some added strings to the release name.
For example
Shark.Tank.S06E07.HDTV.x264-BATV [GloDLS]
Shark.Tank.S06E10.720p.HDTV.x264-W4F[et]
[ www.torrenting.com ] - Shark.Tank.S06E06.HDTV.x264-BATV
[ www.Torrentday.com ] - Shark.Tank.S06E09.720p.HDTV.x264-BATV
After downloading I’d like to keep the original releasename for the files, but in these cases the added text obviously also gets prepended / appended to the filename in post processing. Obviously the releasenames with appended text strings isn’t as horrible to my autistic eyes as the prepended ones, but it’s easy to kill 2 birds with 1 stone.
I’d like to suggest an option that can remove these standard text strings in post processing and that the list can be edited by users when they come across new strings of text.
i reported it earlier:
then @markus101 pointed me to the trello card
@TRaSH’s issue is slightly different as its done in a less intrusive way and is actually part of the release group, not some extra group tag.
Leaving renaming off or using the {Original Title} renaming token uses the original title as you’ve discovered, I’ll give some thought to how we’d want to handle this particular case (another con with torrents).
If the file name isn’t also filled with garbage you could use {Original Filename} as the renaming token, but won’t help when the release has a hashed name.
Thanks @TRaSH for your input, but @markus101 is right about the slight difference in what I meant.
Thanks for taking it into and under consideration! :smile:
Added to Trello: https://trello.com/c/3pvpOjvy/908-clean-pre-post-fixes-from-releases
