Remove part of group tags from filename but keep scene release name
i would like to see a option so i can remove part of group tags from filename but keep scene release name.
nzbToMedia used to have this option but it doesn’t work any more since CDH works with nzbToMedia.
when does it happen ?
some indexers add there name to the end of a scene release name.
so you get "The.Walking.Dead.S05E08.1080p.WEB-DL.DD5.1.H.264-Cyphanix-NZBgeek"
but the actual scene release name is "The.Walking.Dead.S05E08.1080p.WEB-DL.DD5.1.H.264-Cyphanix"
so actually only “-NZBgeek” should be removed from the filename,
there’re more but this is a example of one of them.
it could be like we use now with the Restrictions box we use in the indexers setting.
i don’t want to rename the file completely to something else i want to keep the scene release name for several reasons.
Its not going to be customizable, but its already on Trello: https://trello.com/c/Hutms8Zk/875-remove-rp-and-nzbgeek-before-parsing-release-group
thnx,
i’ve requested to add another group/tracker/indexer name
do i need to change something in the settings so that -NZBGeek get’s removed/cleaned ?
2.0.0.2622 - Jan 10 2015
Saturday, January 10 2015 21:17
Clean title before parsing release group (remove -RP & -NZBGeek)
it downloaded
Resurrection.S02E11.True.Believer.1080p.WEB-DL.DD5.1.H.264-ECI-NZBgeek
but the filename has still -NZBGeek in it.
It only gets removed when parsing the release group.
ahh darn i thought it would remove that part of the filename.
thnx for the fast response
