Sonarr version:2.0.0.4472 OS: Windows 8.1 Pro-64 bit Description of issue: Can not bind Sonarr to IP address 10.0.0.101 port 8090.
I can bind to * 8090 fine, but as soon as I try to bind to the IP address and restart Sonarr, I get an error saying the port is already in use. I also can not access Sonarr remotely using my domain name sonarr.domain.name.My domain name is setup through dynu.com (DDNS), and have a web redirect set to sonarr.domain.name port 8090. My router is forwarded from 8090 to the gateway 8090, as I have a seperate gateway and router.
Running as admin might work, but it will cause issues with remote access because the Bind Address doesn’t work the way it’s expected to work. Instead of binding to a specific IP address it only listens to the defined address so you wouldn’t be able to access it via your hostname properly. We hope to remedy that in the future by changing the webserver.
