Sonarr version (exact version): 2.0.0.5338 Mono version (if Sonarr is not running on Windows): 5.2.0.215 OS: 10.15 Debug logs: Description of issue:
My friend helped me setup Sonarr with Plex so that I can have my shows downloaded and placed automatically in the right folders for Plex.
about two weeks ago, Sonarr stopped moving the files to the write folders. They just remain in download and I have to manually move them to the tv or movie section.
when I go to Sonarr I see this error in red “Unable to write to drone factory folder”
the external hard drive I am using has not changed, it has plenty of space available.
I made sure it has permissions for everyone to read and write.
please help me guys! I really want this to work like it did before and I have no clue how to go about it. I am quite a novice.
There is a workaround, but without a native macOS app there isn’t a fix and even then not sure if that would solve it.
No, Sonarr can get that info right from Transmission. Especially with torrents you shouldn’t use Drone Factory, that would cause Sonarr to move files instead of copying/hardlinking seeding torrents.
