Not a bug report… just wanted to post a quick comment/resolution to an old post that was locked: Manual Import Modal “Glitchy” - v3 Testing - sonarr :: forums
I was experiencing “unable to load manual import items” messages when trying to load files from a cloud mounted folder (rclone in my case, but shouldn’t matter specifically). Bascially the reverse proxy was timing out and closing the connection (as markus101 suggested in that thread).
To resolve i upped that timeout in my nginx config using the following three variables:
proxy_read_timeout 300;
proxy_connect_timeout 300;
proxy_send_timeout 300;
The specific value you set these to is up to you, 5 minutes seems to be enough for me to get about 4 standard seasons of shows (~15 episodes/season) scanned at a time… i might go longer depending on how i make progress otherwise, but just wanted to post this hear in case anyone runs across the same issue.
