exec is part of the upstart script itself. I just modifying the suggested upstart script provided with Sonarr and inserted the taskset: https://github.com/Sonarr/Sonarr/wiki/Autostart-on-Linux
Oh i see, sorry i was using this one:
Not sure how you managed to wreck your system badly enough that it required a re-install. You can just pick the correct kernel during grub bootup. Changing the default isnāt strictly required.
Iām waiting with overwhelming anticipation for -54ā¦
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1458618
@PCJonathan No we donāt need more reports, itās just waiting for the kernel update.
Not sure, iām headless and remote, so i will just wait, not a linux pro. Is this bug specifically related to mono per say? Or could it affect other applications? Just wondering because plex seems to also be dropping.
FYI I pulled the latest early testing builds from the kernel ppa.
All tested on a 14.04.2 trusty vm.
3.13.0-53.x was still crashing. (trusty-updates)
3.13.0-54.61 seems to work. (ppa)
lts-utopic:
3.16.0-38.30 was still crashing. (trusty-updates)
3.16.0-39.31 seems to work. (ppa)
Prolly could use someone versed in linux to try it out on a physical machine. But I take no responsibility if it utterly breaks your machine, coz these are early testing builds. Donāt blindly add the ppa, it gotta be pinned with low priority to avoid unwanted updates.
What does you cron job look like? I tried to do the same but it didnāt work.
Sonarr does self checks on startup to make sure itās not already running and quits if it detects a process already running, so my cron is extremely simple:
cat /etc/cron.hourly/start-sonarr
#!/bin/sh
start nzbdrone
Mine is just:
*/1 * * * * /etc/init.d/nzbdrone start
@Taloth Im going to wait haha. Looking hopeful though.
Thanks @jrhelbert
I get an error unless I use the following to start Sonarr which doesnāt work with cron.
sudo start nzbdrone
It must be something to do with the user that Sonarr is running under or something.
Edit: Never mind, I figured it out!
And the packages just got promoted to trusty-proposed. (and utopic-proposed for those using 14.10)
I need at least 1 person to test this on a physical server. (please reply if youāre going to try this)
Before you start, be sure you can get into the grub boot menu, which allows you to boot back into an older kernel if needed.
Instructions for 14.04 trusty:
Step 1: Add repository source
Edit
/etc/apt/sources.listand add:
deb http://archive.ubuntu.com/ubuntu/ trusty-proposed restricted main multiverse universe
Step 2: Pin it to prevent auto-installs
(using sudoedit for example)
Create/etc/apt/preferences.d/proposed-updateswith the following content:
Package: * Pin: release a=trusty-proposed Pin-Priority: 400
Step 3: Update apt cache
Run
sudo apt-get update
Optional: Verify if pinning is correct:
Runapt-cache policy linux-image-generic
you should see the 3.13.0.53.60 as having the highest (500) priority, with the proposed one at 400 priority.
Step 4: Install kernel
If you have the original trusty 3.13.0 kernel:
- Run
sudo apt-get install linux-image-generic -t trusty-proposed
OR if you have the lts-utopic backported 3.16.0 kernel:- Run
sudo apt-get install linux-image-generic-lts-utopic -t trusty-proposed
Step 5: Reboot (assuming you have the default grub config)
Instructions for 14.10 utopic:
I didnāt test this one myself.
Edit
deb http://archive.ubuntu.com/ubuntu/ utopic-proposed restricted main multiverse universe
Package: * Pin: release a=utopic-proposed Pin-Priority: 400
Run
sudo apt-get update
you should see the 3.16.0.38.30 as having the highest (500) priority, with the proposed one at 400 priority.
Run
sudo apt-get install linux-image-generic -t utopic-proposed
Physical Server here, I just installed and have rebooted into it.
uname -a
Linux server 3.13.0-54-generic #91-Ubuntu SMP Tue May 26 19:15:08 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Iāve gone ahead and removed any of the workarounds (processor affinity, cron, etc) I had put in place and weāll see how it goes. I havenāt had anything that was a surefire trigger, so Iām just going to let it run and do its thing.
Iāll post tomorrow with status.
In hindsight thatās pretty poor planning on my part⦠I rebooted into -53 and ran Sonarr several times without all the workarounds in place. Sure enough itād crash within min either just by turning on or by kicking off a series refresh.
Booted back into -54 and ran the same tests several times without seeing any failures.
Itās looking optimistic, so Iāll just let it run and do its thing now and report back tomorrow.
@jrhelbert Thank you for trying it out.
At least it seems confirmed now that this specific bug affected physical servers as well.
Lets hope this was the only bug causing crashes
Still going strong!
I had seen it go a day or two before without crashing, so Iām going to run longer before I say for certain that itās gone (As opposed to sheer luck). Given how unstable it was after the last Sonarr update though, itās very promising.
I just updated to the proposed kernel on 14.04. Iāll let you know how it works - since the last update it was crashing at the least every 4 hours, as often as every 3 seconds. Iād sometimes have to restart it 6 times just to get the web interface up. Just restarted, Sonarr loaded on boot, refreshed all series, and is happily awaiting work. So far so good. I like Sonarr so much better than the competition, but was getting close to walking away in frustration. Thanks for the hard work.
I was experiencing the same issues, just tried it with the proposed LTS kernel and it seems to work fine now. I will let it run and see if everything goes smoothly.
Linux dakar 3.16.0-39-generic #53~14.04.1-Ubuntu SMP Wed May 27 10:03:17 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
24 hours later, no crashes. Thatās the longest uptime Iāve had since the latest update, and close to the longest uptime Iāve had ever.
Not using a VM either, so this is a pleasant surprise.
Still no crashes! Seems relatively safe to say the issue is fixed, and the same issue affected both Physical as well as Virtual Machines.
I followed your instructions for 14.04 trusty, updated my kernel to 3.13.0-54 and didnāt crashed for 24+ hours.
Thank you.
