Awesome guys, tnx for letting me know. I’ll reported the success to the ubuntu team.
Now it’s wait and see if fixes the crashes ppl have been seeing for Emby as well (@Sek0n)
Thanks for the post man, this solved my problem. I couldn’t get NZBDrone running for more than 60 seconds. Same exact stack trace, everything the same as this.
I downgraded my kernel from .53 down to .46 like you suggested and bewm problem solved. Good stuff, thanks a lot.
Good to see things have been figured out. I’d love to try the instructions for 14.04 but in case anything goes wrong I don’t really have easy access to the physical server at this moment to hook up a keyboard and screen to it. Can I expect the bugfix to be updated automatically over the following days/weeks?
I didn’t read all the posts but I am assuming you need access to the physical server to deal with the grub menu?
I didn’t have access to my physical server, only remote access. It was a bit sketchy and I definitely knocked on wood, but here’s how I did it.
Installed kernel .46
$ apt-get install linux-image-3.13.0-46-generic
Figure out which kernels are installed on ur system
$ dpkg -l | grep linux-image
$ apt-get remove $all_kernel_versions_from_previous_command_except_for_version_46
You will see a message saying grub is broken or vmlinuz doesn’t exist or the symbolic link is busted
$ sudo update-grub
“sudo update-grub” will look for the latest kernel you have installed (which at this point is .46) and will load up next time you reboot by default…Good luck
@sigmundfreund Ubuntu kernel releases are on a 3 week cycle. A public release is expected in just under 2 weeks.
@rizz2pro That would work yes. Although at this point it would either just install -proposed or wait for the actually release.
Thanks for the info! I’ll just leave it as it is then for the next weeks. Not much shows scheduled anyway.
I will be waiting 2 weeks for the new fix… tried to install kernel 46 and 2 hours later I am back on regular booting kernal
I am having an issue, so thought I would post it here:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.04
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION=“Ubuntu 14.04.2 LTS”
$ uname -a
Linux r2d2 3.13.0-53-generic #89-Ubuntu SMP Wed May 20 10:34:39 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
[Trace] Parser: ^(?:[(?.+?)][-. ]?)?(?.+?)(?:(?:|-|\s|.)+(?:e|ep)(?\d{2,3}))+.?(?[\w{8}])?(?:$|.)
[Debug] Parser: Episode Parsed. elefanttigerundco - 409
[Debug] Parser: Language parsed: German
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E409.Sorge.um.Luena.GERMAN.DOKU.720p.HDTV.x264-OWG
[Debug] Parser: Quality parsed: HDTV-720p v1
[Debug] Parser: Release Group parsed: OWG
[Debug] ParsingService: No matching series elefanttigerundco
[Debug] DownloadDecisionMaker: Release rejected for the following reasons: [Permanent] Unknown Series
[Trace] DownloadDecisionMaker: Processing release 575/655
[Trace] EventAggregator: Publishing CommandUpdatedEvent
[Trace] EventAggregator: CommandUpdatedEvent -> CommandModule
[Trace] EventAggregator: CommandUpdatedEvent <- CommandModule
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E407.Die.lieben.Kleinen.GERMAN.DOKU.720p.HDTV.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 407
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E407.Die.lieben.Kleinen.GERMAN.DOKU.720p.HDTV.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 576/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E406.Baerenkinder.GERMAN.DOKU.720p.HDTV.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 406
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E406.Baerenkinder.GERMAN.DOKU.720p.HDTV.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 577/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E405.Das.Schreckgespenst.GERMAN.DOKU.HDTVRip.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 405
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E405.Das.Schreckgespenst.GERMAN.DOKU.HDTVRip.x264-OWG
[Debug] Parser: Quality parsed: SDTV v1
[Trace] DownloadDecisionMaker: Processing release 578/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E404.Halbstarke.Gesellen.GERMAN.DOKU.HDTVRip.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 404
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E404.Halbstarke.Gesellen.GERMAN.DOKU.HDTVRip.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 579/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E403.Der.Letzte.macht.das.Licht.aus.GERMAN.DOKU.HDTVRip.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 403
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E403.Der.Letzte.macht.das.Licht.aus.GERMAN.DOKU.HDTVRip.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 580/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E402.Nicht.zu.fangen.GERMAN.DOKU.HDTVRip.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 402
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E402.Nicht.zu.fangen.GERMAN.DOKU.HDTVRip.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 581/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E401.Gluecksmomente.GERMAN.DOKU.HDTVRip.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 401
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E401.Gluecksmomente.GERMAN.DOKU.HDTVRip.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 582/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E400.Spielzeug.fuer.Dickhaeuter.GERMAN.DOKU.HDTVRip.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 400
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E400.Spielzeug.fuer.Dickhaeuter.GERMAN.DOKU.HDTVRip.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 583/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E399.Auf.Kuschelkurs.GERMAN.DOKU.HDTVRip.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 399
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E399.Auf.Kuschelkurs.GERMAN.DOKU.HDTVRip.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 584/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E398.Ndugu.geht.GERMAN.DOKU.HDTVRip.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 398
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E398.Ndugu.geht.GERMAN.DOKU.HDTVRip.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 585/655
[Debug] Parser: Parsing string ‘Elefant.Tiger.und.Co.E397.Knifflige.Premiere.GERMAN.DOKU.HDTVRip.x264-OWG’
[Debug] Parser: Episode Parsed. elefanttigerundco - 397
[Debug] NzbDrone.Core.Parser.QualityParser: Trying to parse quality for Elefant.Tiger.und.Co.E397.Knifflige.Premiere.GERMAN.DOKU.HDTVRip.x264-OWG
[Trace] DownloadDecisionMaker: Processing release 586/655
[Debug] Parser: Parsing string ‘Eisenbahn.Romantik.XXL.Zwischen.Bodensee.und.Westerwald.German.DOKU.WS.HDTVRiP.x264-UTOPiA’
[Debug] Parser: Unable to parse Eisenbahn.Romantik.XXL.Zwischen.Bodensee.und.Westerwald.German.DOKU.WS.HDTVRiP.x264-UTOPiA
EPIC FAIL: System.NullReferenceException: Object reference not set to an instance of an object
at System.Threading.EventWaitHandle.Reset () [0x00000] in :0
at (wrapper remoting-invoke-with-check) System.Threading.EventWaitHandle:Reset ()
at System.Threading.Timer+Scheduler.SchedulerThread () [0x00000] in :0
at System.Threading.Thread.StartInternal () [0x00000] in :0
[Fatal] GlobalExceptionHandlers: EPIC FAIL: Object reference not set to an instance of an object
Stacktrace:
[Debug] ParsingService: No matching series Eisenbahn.Romantik.XXL.Zwischen.Bodensee.und.Westerwald.German.DOKU.WS.HDTVRiP.x264-UTOPiA
Native stacktrace:
mono() [0x4b3f7c]
mono() [0x50c30f]
[Trace] DownloadDecisionMaker: Processing release 587/655
mono() [0x423637]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f3317416340]
[0x4045ea28]
Debug info from gdb:
[Debug] Parser: Parsing string ‘Eisenbahn.Romantik.XXL.Zwischen.Bodensee.und.Westerwald.German.DOKU.720p.HDTV.x264-UTOPiA’
[Debug] Parser: Unable to parse Eisenbahn.Romantik.XXL.Zwischen.Bodensee.und.Westerwald.German.DOKU.720p.HDTV.x264-UTOPiA
Could not attach to process. If your uid matches the uid of the target
process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
again as the root user. For more details, see /etc/sysctl.d/10-ptrace.conf
ptrace: Operation not permitted.
No threads.
Aborted (core dumped)
15-6-1 13:36:25.5|Debug|Parser|Quality parsed: SDTV v1
15-6-1 13:36:25.5|Debug|Parser|Release Group parsed: OWG
15-6-1 13:36:25.5|Debug|ParsingService|No matching series elefanttigerundco
15-6-1 13:36:25.5|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Unknown Series
15-6-1 13:36:25.5|Trace|DownloadDecisionMaker|Processing release 584/655
15-6-1 13:36:25.5|Trace|EventAggregator|Publishing CommandUpdatedEvent
15-6-1 13:36:25.5|Trace|EventAggregator|CommandUpdatedEvent -> CommandModule
15-6-1 13:36:25.5|Trace|EventAggregator|CommandUpdatedEvent <- CommandModule
15-6-1 13:36:25.5|Debug|Parser|Parsing string 'Elefant.Tiger.und.Co.E398.Ndugu.geht.GERMAN.DOKU.HDTVRip.x264-OWG’
15-6-1 13:36:25.5|Trace|Parser|^(?:[(?.+?)][-. ]?)?(?.+?)(?:(?:|-|\s|.)+(?:e|ep)(?\d{2,3}))$
15-6-1 13:36:25.5|Debug|Parser|Episode Parsed. elefanttigerundco - 398
15-6-1 13:36:25.5|Debug|Parser|Language parsed: German
15-6-1 13:36:25.5|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Elefant.Tiger.und.Co.E398.Ndugu.geht.GERMAN$
15-6-1 13:36:25.5|Trace|DownloadDecisionMaker|Processing release 585/655
15-6-1 13:36:25.5|Debug|Parser|Parsing string 'Elefant.Tiger.und.Co.E397.Knifflige.Premiere.GERMAN.DOKU.HDTVRip.x264-OWG’
15-6-1 13:36:25.5|Debug|Parser|Episode Parsed. elefanttigerundco - 397
15-6-1 13:36:25.5|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Elefant.Tiger.und.Co.E397.Knifflige.Premier$
15-6-1 13:36:25.5|Trace|DownloadDecisionMaker|Processing release 586/655
15-6-1 13:36:25.5|Debug|Parser|Parsing string 'Eisenbahn.Romantik.XXL.Zwischen.Bodensee.und.Westerwald.German.DOKU.WS.HDTVRiP.x264$
15-6-1 13:36:25.5|Debug|Parser|Unable to parse Eisenbahn.Romantik.XXL.Zwischen.Bodensee.und.Westerwald.German.DOKU.WS.HDTVRiP.x264$
15-6-1 13:36:25.5|Fatal|GlobalExceptionHandlers|EPIC FAIL: Object reference not set to an instance of an object
15-6-1 13:36:25.6|Debug|ParsingService|No matching series Eisenbahn.Romantik.XXL.Zwischen.Bodensee.und.Westerwald.German.DOKU.WS.H$
15-6-1 13:36:25.6|Trace|DownloadDecisionMaker|Processing release 587/655
15-6-1 13:36:25.6|Trace|EventAggregator|Publishing CommandUpdatedEvent
15-6-1 13:36:25.6|Trace|EventAggregator|CommandUpdatedEvent -> CommandModule
15-6-1 13:36:25.6|Trace|EventAggregator|CommandUpdatedEvent <- CommandModule
15-6-1 13:36:25.6|Debug|Parser|Parsing string 'Eisenbahn.Romantik.XXL.Zwischen.Bodensee.und.Westerwald.German.DOKU.720p.HDTV.x264-$
Do u happen to know if a fix is coming for debian as well? Or should I move the install to ubuntu if I plan to have it fixed fast?
Yes there’s also a fix for debian out, check the link to the debian bugreport in the first post for the version you have to install.
I moved 3 posts to a new topic: Sonarr crashing and tasks stuck
Just registered to let you know that upgrading the kernel stabilized Sonarr for me. Was receiving the NullReferenceException/Timer issue. Physical hardware, not virtual.
Now running:
It’s been running for two days rock solid.
Thanks for your hard work and cooperation with researching this issue, rather than brushing it off as “not my problem.” Refreshing.
Last post from me on this one, 10 days and only 1 crash, and that’s unrelated. I have some weird issue that seems to rarely pop up that gives me a Ubuntu file system error and that happens at the same time Sonarr crashes. Since it happened like 8 days ago, and I’ve tinkered heavily with the config since, I’m thinking I may have “solved” it. Either way the upgrade to the Ubuntu beta kernel completely solved the mono crashes. Thanks again for all your hard work.
are you using mhddfs? if so downgrade to 0.1.38 as there is a bug in .39
https://bugs.launchpad.net/ubuntu/+source/mhddfs/+bug/1429402
I’m not, thanks for the info though
Hey guys, didn’t get to post about this earlier, was away for week.
The kernel fixes were released public last Thursday, so will be available to users via the normal OS update process.
I would like to thank those users that installed the -proposed kernels earlier to test them out. I appreciate your effort to validate it for me.
You might want to comment out or remove the -proposed entry in sources.list again just to be safe.
If someone still experiences these crashes, and you’re sure you are on the latest kernel, please open a new topic.
I moved a post to an existing topic: Native mono crash on linux kernel 4.1.2
