- it appears that even though in Manual Import you select the Series, Season and Episode it is always parsing the file name to find the Season and Episode. This results in the error if the filename does not include the season/episode number in a correct format.
Couldn’t import episode xxxxxxxxx: Expected one season, but found none
- Further, I can no longer change the ‘Series Type’ foe a Series, changing Daily to Standard and Save, still leaves the series type as Daily.
These issues appear to have been happening since 2.0.0.5225
thanks.
