So, I just switched to Sonarr from SickRage because I’ve heard a lot of great things. I like what I see, but I’m having some issues.
I only use DogNZB as an indexer. I think I’ve configured everything right, but I’m not getting any RSS sync results. I tried waiting for a few shows tonight, and even if I can see them in Dog’s RSS feed, Sonarr always says that there are zero reports downloaded. Am I doing something wrong? Sync and Search are enabled. I’m using https://api.dognzb.cr as the URL and I know my API is right. Categories are 5030 and 5040, Interval is set to 15, and Minimum Age and Retention are set to 0.
As for automatic search, sometimes it works; sometimes it doesn’t. Even if I can see the episode in the RSS feed, sometimes doing an automatic search doesn’t do anything. Any ideas?
Is there a way to add some options for show names? What I mean is that it seems like Sonarr needs an exact match in order to function correctly. If I have “Show Name s01e01” in the Drone Factor, but it’s entered into Sonarr as “Show Name (2014) s01e01,” it seems like it won’t get processed. SickRage could usually parse stuff like this out. Am I SOL with Sonarr?
Thanks, guys!
