[Jackett] Additional torrent trackers for Sonarr
Hello,
I am very new to using automation to setup TV and Movies. I have installed Sonarr with a torrent client in Mac OS X 10.11. I am now trying to install Jackett. I have Mono already installed. I am having a very hard time figuring out how to find and install the correct version of libcurl. I am looking for someone that can help me find the correct version of libcurl and walk me through the process of installing it.
Thank you so much!
hello if i download source files and do some changes ( to add custom provider ) is possible to run it from the specific files?
Hello. I’ve been running jackett on my unraid server as a docker for the last few months and it has been working perfect but i recent upgraded from version 6.45 to the latest and the only two providers i was using (torrentz and the pirate bay) seem to be missing from the newest release. am i just missing something or are these two providers not included in this new release?
Thanks
All public trackers have been removed.
You can fin informations about that on github.
Hello!
I have a issue where I only can see a white page / page not found (error 404), I have followed a guide provided by feralhosting on how to set up jackett, but I keep getting the same error.
I now tried on multiple services and it is the same on all of them.
I have Mono installed, and running Nginx
I hope someone can help me with this issue
/naniq
Okay I fixed my issue with white page, now the only issues I have if that if I try to add Hounddawgs i get:
Configuration failed:
Nothing else it just says that, any idea what it can be?
You can check github, I guess there is already an issue opened for that.
I must be loosing it. Can someone please point me to the log file location when using the SynoCommunity package. Can’t seem to locate it.
That’s really unfortunate :frowning:
Adding unsupported trackers through Jackett was nice.
Please remember to fllow this fork now.
The original project hibernates now…
WOW! just tried it. One of the most amazing/useful addons ever! Should be integrated into sonarr without question asap!
Héhé! Good to hear!
Hey,
Thanks for plugin
Can anyone point me at an updated OS X install guide - https://github.com/Jackett/Jackett#installation-on-linuxosx really isn’t very helpful?
Hope to hear back
Kind thanks
BUMP
Can anyone point me at an updated OS X install guide - https://github.com/Jackett/Jackett#installation-on-linuxosx1 really isn’t very helpful?
How’d you go in the end mate? I’m not really sure how to install it to a QNAP NAS either.
Cheers
If anyone is interested, I’m working on an alternative to Jackett: https://github.com/cardigann/cardigann
Limited in what trackers it offers currently, but should work out of the box on OSX @ldexterldesign.
Hi @lxt2
I will follow your project closely, good luck!
I was close to contact you to connect with @ldexterldesign but it seems already done :slight_smile:
Hey all,
@lxt2 thanks for the heads up, I’ll try the install today
https://docs.google.com/spreadsheets/d/1WZ3RS3HA7tdRqMU2PXPEUYWGqrG1TnnguEJ6NbWJa-A/ is a (not so) little resource you may be interested in - DM me your email and I’ll invite you
@anon70424920 :stuck_out_tongue_winking_eye:
Regards
Not sure how I DM you, perhaps I don’t have privs yet. I requested access, cheers!
Can someone point me towards a good guide on installing this build? Or a guide for installing any build and I can modify it to install this.
I am running the official Sonarr release on my MacOS and I’d like to switch to something with more torrent options. Sorry for the newb question, I have some technical ability but I just need a little nudge in the right direction. Thanks!
