Sonarr version (exact version): 2.0.0.4949
Mono version (if Sonarr is not running on Windows): Mono JIT compiler version 3.10.0 (mono-3.10.0-branch/ce003f4 Tue Nov 25 20:18:29 UTC 2014)
OS: Raspberry Pi3 Raspbian Stretch (September 2017 Version, 4.9 Kernel Version)
I have ‘extra’ information that I don’t want to into my Serie’s folder and episode name even I told Sonarr to rename it, it seems that or renaming is not taking place or I’ve a misconfiguration here. Let me show how I’ve the things configured:
Settings in Media Management, Episode Naming (Drone Factory is leaved in blank):
Rename Episodes: Yes
Include Series Title: Yes
Include Episode Title: No
Include Quality: No
Replace Spaces: Yes
Separator: Period (.)
Numbering Style: S01E05
Season Folder Format: Season{season}
Multi-Episode Style: Extend
Single Episode Example: The.Series.Title.(2010).S01E01
Multi-Episode Example: The.Series.Title.(2010).S01E01-02-03
Daily-Episode Example: The.Series.Title.(2010).2013-10-30
Anime Episode Example: The.Series.Title.(2010).S01E01
Anime Multi-Episode Example: The.Series.Title.(2010).S01E01-02-03
Series Folder Example: The Series Title (2010)
Season Folder Example: Season1
For the Download Client I use Deluge with the following settings at the Downloads Category:
Download to: /media/pi/Series&Pelis/Downloads/Series/Incompletos
Move completed to: /media/pi/Series&Pelis/Downloads/Series/Descargados
Copy of .torrent files to: /media/pi/Series&Pelis/Downloads/Torrents
Autoadd .torrent foles from: /media/pi/Series&Pelis/Downloads/Series/Torrents
The rest of the Sonarr configuration at the Download Client is the following:
Completed Download Handling:
Enable: Yes
Remove: Yes
Failed Download Handling:
Redownload: Yes
Remove: Yes
But when I go to the final folder (/media/pi/Series&Pelis/Downloads/Series/Descargados) I got the following inside:
Folder name: Bojack.Horseman.S04E01.WEB.x264-STRiFE[rarbg]
File name: bojack.horseman.s04e01.web.x264-strife.mkv
The bulk renaming operation (Organize & Rename) for a serie’s season tells me “Success! My work is done, no files to rename.” This could be due to that I’ve the path set to a different location (that’s where I have all my series properly organized and named: /media/pi/Series&Pelis/Series/BoJack Horseman/)
What I want to achieve is to have Sonarr being fed by my ShowRSS feed, then Deluge will download the desired episode automatically, and once downloaded it’ll seed for a 3.00 ratio, and once finished, it’ll be removed from the BTClient, but in the disk I should have the proper /media/pi/Series&Pelis/Downloads/Series/Descargados/Bojack.Horseman/Season4/Bojack.Horseman.S04E01.mkv renamed file (don’t really know when the renaming operation is being done, if once it has finished the downloading or when it has finished seeding) or if possible, to the real final folder: /media/pi/Series&Pelis/Series/BoJack Horseman/SeasonX/Bojack.Horseman.S0XEXX.mkv
Found this case from 2015, but in that one, the guy wanted to leave all that ‘extra’ information I don’t want to: [Help] Sonarr not renaming files correctly
Could you please help me with this? THX!
