Version: whatbox-31fe942
Description of issue: I had a backend issue causing some files not to save and were lost. How can I have Sonarr reimport files already imported? Without marking the download as failed or downloading a different torrent, how can I have Sonarr simply reimport the same file again?
In example, The Show Season 2 Episode 4 downloaded correctly. Everything was imported and worked flawlessly. After Sonarr completed its job, the file was removed from the library. All I need Sonarr to do is re-copy the file from the download client to the library.
