**Sonarr version: 2.0.0.5163 Mono version (if Sonarr is not running on Windows): OS: Windows 10 Debug logs: (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here. Post in .txt not .doc, .rtf or some other formatted document) Description of issue:
Unless something has changed and kodi is not currently up on it, most Bamboozle rleases stutter or play in slow motion, like it’s skipping frames. No other release I play does this, only that group.
How do I put them in as something for sonarr to ignore so I can have good releases.
Apologies to bamboozle if it’s just one guy messing things up, but since sonarr downloads a regular release, then it grabs a web release, I tend to have a working copy overwritten with a bad one. The Flash and the arrow 720p were both bad.
Regardless, I’d like to know how to ignore their releases.
Yeah this works perfectly. Just make sure you have advanced settings turned on so that you can see the field. It’s essentially just a text filter that will ignore those releases when their name is found in the title of the post.
