The file exist, it has been DL after Sonarr checked the availability and yes, i’ve checked permissions.
It exists in that exact path?
Since you’re attempting to test whether its WebDAV thats not working I assume you copied it there manually?
In terminal what do you see if you run ls -la /Volumes/Mac Mini HD/Users/antoinebachelay/Downloads/Torrents/Sonarr/?
You’re right :
Hi,
Please let me know if you need more.
Not sure what you meant by this, try wrapping the path in quotes.
The issue is either the permissions (the user running Sonarr doesn’t have access), is it running as your user?
Or the path doesn’t exist, from the screenshot it looks like it exists, so it sounds like a permissions problem.
You’re right about this :
OKay, then it sounds like permissions. If Sonarr is running as your user it shouldn’t be a problem, but you could try using Manual Import to test that you can import it with that.
