Sonarr version (exact version): 2.0.0.5225
OS: Windows 7
Debug logs:Trace Log Here
Having issues with the websocket/signalR not working. I have Googled the issue a lot and found several forum posts that have the same issue, but they are running on docker/mono/ some NAS product
Same issue as me: https://forums.sonarr.tv/t/gui-update-issues/4195/2
This is happening on Windows 7 I get this error in Chrome console
http://servername:8989/signalr/negotiate?apiKey=removed&_=1529555956433 500 (Internal Server Error)
Local LAN, no firewalls, etc
I have removed .NET framework, rebooted and reinstalled
I have wiped out the config.xml, logs.db, and nzbdrone.db files to reset sonarr
I am out of ideas on where the issue is. The interface works fine except I dont see any popup in the bottom right corner saying its scanning or updating something, also the calendar and activity screens dont update on the fly either, not without hitting F5 in the browser.
