I have no maximum with 0 Byte. Why does this error come up, and how to get rid of it.
This are my quality settings:
Its a bug when Sonarr isn’t able to match the release to the episode (which I believe we already have a fix for), there isn’t a work around as Sonarr doesn’t let you manually download a release it can’t map to a series + episode.
Im not quite sure if I get you. Apperatly Sonarr does match the release to the episode, otherwise why would it show me this release by clicking on “manual search”. But it rejects the release for some reason.
It shows all results that your indexer returned, whether or not they are linked to an episode. I’m not sure why exactly its rejected, but ((debug logs)) will tell you.
I had the same issue with nightly show. Once I removed it and re added it selecting the show as “daily” everything works fine.
