Sonarr version (exact version): 2.0.0.4099
**Mono version (if Sonarr is not running on Windows)☆: 4.2.1 (Stable 4.2.1.102/6dd2d0d Sat Nov 21 10:02:10 EST 2015) OS: It’s on a QNAP x86 unix-based
Mark, is it an idea to ignore size check if runtime is zero and log a warn instead? My guess would be tvdb vandalism, we could also just block updates without runtime on skyhook.
I think I’d prefer blocking it via skyhook since the import process also relies on the runtime (for determining sample length limits), plus it would stop us from serving up garbage data.
