If somebody could make an add-on for Kodi that could use Sonarr’s EpisodeService: to set Monitored flag for Episodes:xxx to False after an episode been watched. That would be fantastic!
If there’s any interest in this I could help gather information needed to make this happen.
I think that would be great. In Sonarr i have set most episodes to first download the HDTV en then the WEB-DL if available. It happens a lot that i watch an episode when it is still a HDTV rip. A day later the WEB-DL is downloaded and the status is unwatched again in Kodi.
With the add on this would be eliminated. The WEB-DL would be flagged as watched and a new download is not needed.
I wrote a bash script that does that. Runs on the server sonarr is. Fetches the last 25 episodes on kodi using api, then filter by watched (play count >0) finally then using the sonarr api sets unmonitor. This prevents getting propers when you alrwady watched an episode.
Runs in Cron every hour, not very efficient but does the job.
I use it in the server because I have a firetv and to have bash there would mean to root the device, also the script uses jq binary to filter json.
