**Sonarr version : 2.0.0.3953
**Mono version 4.2.2
**OS: QNAP (qmono) Description of issue (if you think you’ve found a bug please include steps to reproduce):
Hi,
First of all, thanks for your wonderfull app ! It’s amazing how it works so well.
I have a small issue with the auto unmonitor feature and Kodi (used on android tv) : when I delete the episode from Kodi (Remove from Library), Sonarr doesn’t un-monitor it automatically, despite the “Ignore Deleted Episodes” option activated.
However, when I delete it through the finder on my mac, it works perfectly…
Any clues that could resolve my issue ? Thanks in advance !
Because an episode in Sonarr will be unmonitored if its missing from the disk.
The only problem here, that I can see at first glance. You state that series are rescanned every 12 hours. During that time frame an replacement (if any) would most probably have been downloaded already. So is it possible to change this interval? or possibly enhance it so that it can detect instantly.
Or as a last resort until something better comes along. A way to trigger a rescan i Sonarr from After Watch ?
If it can execute a command of your choosing, then you could, you’d need to use Sonarr’s API to rescan the series folder.
Not possible currently and not something we’re going to support.
That just means you set Drone Factory interval to zero, which is fine and has nothing to do with rescanning the series folder.
When you delete from Kodi does it remove the series folder as well (if there aren’t any other episodes in the folder)? If so that would prevent Sonarr from rescanning the folder and seeing that it was deleted.
