Downloading The Same Episodes To Completion then Deleting, Over & Over
Ver. 2.0.0.4949
OS: Unraid 6.3.5
((Debug logs)):
https://pastebin.com/EhnDHsAY
Episode gets thrown to NZBget to download in 720p format. Download completes, shows up as completed in Sonarr and NZBget and then in less than 1 minute, the completed file is gone, removed from NZBget’s download history and Sonarr throws the 1080p version of this episode to NZBget for downloading. Then when that finishes, the cycle repeats and tries to download 720p file again and on and on it goes.
I have 0 idea how or why this is happening.
It seems there was a sort of similar issue at the link below, but it was about remote locations, which I’m not using: Multiple Downloads of same episode
Any help would be appreciated.
Thanks!
Which releases are you seeing this with (so I know what I’m looking for in the log file)?
So after a fair bit of head scratching, I figured out that I had the VideoSort post-processing script imported from my previous setup that was moving the files to a directory that Sonarr and NZBget couldn’t see. Once I removed the script, everything worked as it should.
Thanks for the support and sorry for wasting your time!
That would explain why Sonarr was seeing them as failed. Glad it’s working.
17-8-31 15:07:33.4|Debug|TrackedDownloadService|Tracking 'NZBGet:Claws.S01E10.Avalanche.1080p.AMZN.WEB-DL.DDP5.1.H.264-ViSUM': ClientState=Failed SonarrStage=Downloading Episode='Claws - S01E10 WEBDL-1080p v1' OutputPath=/tv/Claws.S01E10.Avalanche.1080p.AMZN.WEB-DL.DDP5.1.H.264-ViSUM.
17-8-31 15:07:33.4|Debug|DownloadEventHub|[Claws.S01E10.Avalanche.1080p.AMZN.WEB-DL.DDP5.1.H.264-ViSUM] Removing download from NZBGet history
17-8-31 15:07:33.4|Debug|Nzbget|[Claws.S01E10.Avalanche.1080p.AMZN.WEB-DL.DDP5.1.H.264-ViSUM] Deleting folder '/tv/Claws.S01E10.Avalanche.1080p.AMZN.WEB-DL.DDP5.1.H.264-ViSUM'.
17-8-31 15:07:33.6|Debug|RedownloadFailedDownloadService|Failed download only contains one episode, searching again
