Sonarr version (exact version): 3.0.1.458
OS: Synology DSM 6.1 (dockered sonarr from linuxserver.io)
Description of issue: It is rather a question than an issue.
I’ve read that you guys were against implementing the custom format from radarr so I’ve tried to play with the preferred tags instead.
But i have a question. I’ve setup numerous series with cut off quality at 1080p WEB-DL but also some preferred tags like AMZN or NF or dolby, …
Sadly it will happen that a 1080p WEB-DL release is out before an AMZN one is. Will sonarr keep looking automatically for those preferred tags if the cutoff quality is met ?
If not, radarr has a custom format cutoff setting, could be an idea to have a cutoff score setting based on the preferred tags (if you really are against custom format still)
