Sonarr version (exact version): 3.0.4.1021
Mono version (if Sonarr is not running on Windows): 6.10.0.104
OS: Ubuntu 20.04
Debug logs: 20-11-30 08:15:16.8|Debug|Api|[GET] /api/v3/health: 200.OK (0 ms)20-11-30 08:1 - Pastebin.com
I have Deluge running in a container with a Let’s Encrypt SSL certificate. Since upgrading to V3 of Sonarr, it will not connect to the downloader unless I disable Certificate Verification. The SSL certificate is showing valid everywhere else I connect to deluge, so looking for help in how I can get Sonarr to connect as well.
Similar to:
cert-sync should fix it, you shouldn’t need to run it against a specific cert, it’s just a matter of making sure the LE certs are supported by boring TLS/mono.
cert-sync did seem to fix it, but I did have to specify the fullchain.pem file in order for it to work.
Thanks!
Is this a Let’s Encrypt provided file or something else?
It’s a Let’s Encrypt provided file that is provided alongside the cert, privkey and chain files when you request a cert
