1: Can someone please have a look at the parsing code for ‘Anime Episode Format’ input. It is still broken. Here is also an earlier problem with that section.
2: Would you consider changing the name of this section from ‘Anime’ to ‘Absolute Episode Format’ seeing that is what it is following, and it is actually more clear about the purpose of the section.
Sonarr won’t parse a single digit absolute episode number, use {absolute:00} instead.
No, Anime matches the series type, you can also not even include the absolute episode number in the format, relying on Season + Episode numbering instead.
Ex. every show that has it’s aired order screwed by the network and then it’s release gets corrected in a DVD/Blu release ie. Firefly, Futurama etc for two big examples
Sonarr would need to support DVD ordering to handle grabbing episodes for those series though, sure you could set it the type to Absolute, but Sonarr would never find anything because they’re released with season numbers.
you’re wrong in my opinion, more flexible doesn’t have to mean more complicated. Have the current naming conventions there as defaults then you have an input field underneath for spawning more. Having different naming sets linked to tags could allow for diverse ordering for things like dvd-ordering etc when needed.
More flexibility is inherently more complicated it adds another layer of possible problems and another thing to troubleshoot when things aren’t working right.
Even if we add support for DVD ordering there doesn’t need to be another naming format, it would happen automatically.
