WWE Programming and NZBDrone
Hey guys,
Just wondering if anyone has figured out a way to get WWE programming into NZBDrone.
i have done some research on the project and have found that theTVDB have outlawed updating the shows that are already there so I know that’s out. Also the TVrage ordering of episodes are in seasons rather than by air date so I’m not sure if that can be used to add it into NZBDrone…
Anyone got any ideas??
Thanks!
If you’re a member of dog nzb, it might be worthwhile to try using their watched lists, since tvdb doesn’t have up to date information using it with drone is not going to work.
