I hope this is ok to put in help & support, but please move it if it’s not appropriate.
the only kickass proxy i’ve found that works fully with sonarr appears to be down and i can’t find another one (yet, hopefully), so i was wondering if any other UK users knew of any ?
Maybe you could update here as and when you find ones that work ?
thanks for the reply but that didn’t work for me - i get this in the logs
> NzbDroneErrorPipeline Invalid request Validation failed:
> -- Unable to connect to indexer, check the log for more details 3:48pm
> KickassTorrents Unable to connect to indexer: Expected >, but found c [99] Line 35, position 12.: Expected >, but found c [99] Line 35, position 12. 3:48pm
> -- Unable to connect to indexer, check the log for more details 3:47pm
> KickassTorrents Unable to connect to indexer: Expected >, but found c [99] Line 35, position 12.: Expected >, but found c [99] Line 35, position 12. 3:47pm
rather bizarrely, it let me access it initially before i typed this reply but then i’ve just gone back to try it again to find it’s now blocked by Sky …
no worries, thanks for the reply. there are a good few working kickass proxies out there but none of them seem to work with sonarr apart from the one i’ve been using.
If i can’t find one, i’ll have to install sickrage and use that instead as that tends to do a lot of the proxy work automatically. the last time i used it it just never really did much or found anything though, so that’s why i prefer sonarr.
this is quite weird because i still can’t actually access the kickass proxy if i try to open it in chrome, or even if i try accessing it on my phone, but i’ve just got notificiations that it’s successfully downloaded and sorted the latest two shows i monitor - implying that it’s actually working.
eztv has never worked on sonarr for me though, even before all of this trouble. i must have tried over thirty different proxies and none of them tested ok.
working nicely for me at the moment. i think the devs are working to add rarbg support to replace eztv, and there are plenty of working proxies for that as well.
