I know the issue has been discussed, but I’m not sure if a workaround has been sought out…
Now with the eztv rss being down and sonarr not supporting square brackets, eztv and ettv torrents are being ignored which is a big bummer. Is there any sort of work around I can employ so that sonarr will recognize eztv and ettv torrents?
P.S. Thanks for the awesome service! Just got into this and my mind is blown.
It really depends on the series title, square brackets cause issues with “The 100” because it treats “100” as absolute episode 100, but otherwise it should be fine.
Thanks for the explanation. So weird… I spent the last 15 minutes looking for an example so I could screenshot it, but can’t for the life of me find one. Now it appears they are all working. I noticed these yesterday, any chance something changed that is allowing these to work since yesterday?
Found one… I’m wondering if this has more to do with the fact that there are two shows called “the slap”… (all of the ones with “Hector” in the title are NOT the one I want)… That’s my guess, it’s no the square brackets, it’s that the titles don’t contain enough information.
