estaman
February 17, 2016, 8:09am
1
Hi Appreciate any help,
I installed Sonarr using the installation guide on whatbox. I got onto it and set a password as advised. I could not fins the restart command - stupid I know - and i clicked the interface button to restart.
Now when i login to the server, i get the four balls moving back and forth perpetually.
What information do you need from me to help solve this problem?
El
Check the log files for errors, also try another browser.
estaman
February 17, 2016, 9:32pm
3
hi Markus101,
thanks for the reply. I tried another browser without success. Here are the log files:
16-2-17 21:27:04.6|Info|Bootstrap|Starting Sonarr - /mnt/sdu1/jones/NzbDrone/NzbDrone.exe - Version 2.0.0.3732
16-2-17 21:27:05.4|Debug|ProcessProvider|Found 0 processes with the name: NzbDrone.Console
16-2-17 21:27:05.5|Debug|ProcessProvider|Found 1 processes with the name: NzbDrone
16-2-17 21:27:05.5|Debug|ProcessProvider| - [20331] NzbDrone
16-2-17 21:27:05.8|Info|MigrationLogger|*** Migrating data source=/home/jones/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
16-2-17 21:27:06.2|Debug|MigrationLogger|Took: 00:00:00.3732603
16-2-17 21:27:06.2|Info|MigrationLogger|*** Migrating data source=/home/jones/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
16-2-17 21:27:06.3|Debug|MigrationLogger|Took: 00:00:00.0715988
16-2-17 21:27:06.3|Info|Router|Application mode: Interactive
16-2-17 21:27:06.3|Debug|Router|Console selected
16-2-17 21:27:06.3|Info|OwinHostController|Listening on the following URLs:
16-2-17 21:27:06.3|Info|OwinHostController| http://*:12927/
16-2-17 21:27:06.5|Debug|OwinAppFactory|Attaching NzbDroneVersionMiddleWare to host
16-2-17 21:27:06.5|Debug|OwinAppFactory|Attaching SignalRMiddleWare to host
16-2-17 21:27:06.5|Debug|OwinAppFactory|Attaching NancyMiddleWare to host
16-2-17 21:27:06.6|Info|NancyBootstrapper|Starting NzbDrone API
16-2-17 21:27:06.9|Trace|EventAggregator|Publishing ApplicationStartedEvent
16-2-17 21:27:08.0|Trace|EventAggregator|ApplicationStartedEvent -> UserService
16-2-17 21:27:08.0|Trace|EventAggregator|ApplicationStartedEvent <- UserService
16-2-17 21:27:08.0|Trace|EventAggregator|ApplicationStartedEvent -> DownloadClientFactory
16-2-17 21:27:08.0|Debug|DownloadClientFactory|Initializing Providers. Count 11
16-2-17 21:27:08.1|Trace|EventAggregator|ApplicationStartedEvent <- DownloadClientFactory
16-2-17 21:27:08.1|Trace|EventAggregator|ApplicationStartedEvent -> IndexerFactory
16-2-17 21:27:08.1|Debug|IndexerFactory|Initializing Providers. Count 14
16-2-17 21:27:08.1|Trace|EventAggregator|ApplicationStartedEvent <- IndexerFactory
16-2-17 21:27:08.1|Trace|EventAggregator|ApplicationStartedEvent -> ReconfigureLogging
16-2-17 21:27:10.3|Info|HousekeepingService|Running housecleaning tasks
16-2-17 21:27:10.3|Info|SceneMappingService|Updating Scene mappings
16-2-17 21:27:10.5|Info|Database|Vacuuming Log database
16-2-17 21:27:10.5|Info|Database|Log database compressed
16-2-17 21:27:10.5|Info|Database|Vacuuming Main database
16-2-17 21:27:10.6|Info|Database|Main database compressed
Thats the start of the log file during startup, you’ll need to look for an error later when connecting to Sonarr.
Also check the browsers dev tools for any errors.
estaman
February 18, 2016, 1:26am
5
Here is the latest:
16-2-17 21:34:46.4|Info|RssSyncService|RSS Sync Completed. Reports found: 42, Reports grabbed: 0
16-2-17 21:50:09.7|Info|RssSyncService|Starting RSS Sync
16-2-17 21:50:10.0|Info|DownloadDecisionMaker|Processing 42 releases
16-2-17 21:50:10.2|Info|RssSyncService|RSS Sync Completed. Reports found: 42, Reports grabbed: 0
16-2-17 22:05:40.2|Info|RssSyncService|Starting RSS Sync
16-2-17 22:05:40.4|Info|DownloadDecisionMaker|Processing 42 releases
16-2-17 22:05:40.6|Info|RssSyncService|RSS Sync Completed. Reports found: 42, Reports grabbed: 0
16-2-17 22:21:10.4|Info|RssSyncService|Starting RSS Sync
16-2-17 22:21:10.6|Info|DownloadDecisionMaker|Processing 42 releases
16-2-17 22:21:10.8|Info|RssSyncService|RSS Sync Completed. Reports found: 42, Reports grabbed: 0
16-2-17 22:36:10.8|Info|RssSyncService|Starting RSS Sync
16-2-17 22:36:11.0|Info|DownloadDecisionMaker|Processing 42 releases
16-2-17 22:36:11.2|Info|RssSyncService|RSS Sync Completed. Reports found: 42, Reports grabbed: 0
16-2-17 22:51:41.1|Info|RssSyncService|Starting RSS Sync
16-2-17 22:51:41.3|Info|DownloadDecisionMaker|Processing 42 releases
16-2-17 22:51:41.5|Info|RssSyncService|RSS Sync Completed. Reports found: 42, Reports grabbed: 0
16-2-17 22:59:41.6|Info|SceneMappingService|Updating Scene mappings
16-2-17 23:06:41.7|Info|RssSyncService|Starting RSS Sync
16-2-17 23:06:41.8|Info|DownloadDecisionMaker|Processing 42 releases
16-2-17 23:06:42.0|Info|RssSyncService|RSS Sync Completed. Reports found: 42, Reports grabbed: 0
16-2-17 23:21:42.2|Info|RssSyncService|Starting RSS Sync
16-2-17 23:21:42.3|Info|DownloadDecisionMaker|Processing 40 releases
16-2-17 23:21:42.5|Info|RssSyncService|RSS Sync Completed. Reports found: 40, Reports grabbed: 0
16-2-17 23:37:12.4|Info|RssSyncService|Starting RSS Sync
16-2-17 23:37:12.7|Info|DownloadDecisionMaker|Processing 40 releases
16-2-17 23:37:12.9|Info|RssSyncService|RSS Sync Completed. Reports found: 40, Reports grabbed: 0
16-2-17 23:52:42.7|Info|RssSyncService|Starting RSS Sync
16-2-17 23:52:42.8|Info|DownloadDecisionMaker|Processing 40 releases
16-2-17 23:52:43.0|Info|RssSyncService|RSS Sync Completed. Reports found: 40, Reports grabbed: 0
16-2-18 00:08:13.0|Info|RssSyncService|Starting RSS Sync
16-2-18 00:08:13.2|Info|DownloadDecisionMaker|Processing 40 releases
16-2-18 00:08:13.4|Info|RssSyncService|RSS Sync Completed. Reports found: 40, Reports grabbed: 0
16-2-18 00:23:14.3|Info|RssSyncService|Starting RSS Sync
16-2-18 00:23:14.4|Info|DownloadDecisionMaker|Processing 40 releases
16-2-18 00:23:14.6|Info|RssSyncService|RSS Sync Completed. Reports found: 40, Reports grabbed: 0
16-2-18 00:38:14.8|Info|RssSyncService|Starting RSS Sync
16-2-18 00:38:15.1|Info|DownloadDecisionMaker|Processing 40 releases
16-2-18 00:38:15.3|Info|RssSyncService|RSS Sync Completed. Reports found: 40, Reports grabbed: 0
16-2-18 00:53:15.4|Info|RssSyncService|Starting RSS Sync
16-2-18 00:53:15.6|Info|DownloadDecisionMaker|Processing 40 releases
16-2-18 00:53:15.7|Info|RssSyncService|RSS Sync Completed. Reports found: 40, Reports grabbed: 0
16-2-18 01:08:16.0|Info|RssSyncService|Starting RSS Sync
16-2-18 01:08:16.1|Info|DownloadDecisionMaker|Processing 40 releases
16-2-18 01:08:16.3|Info|RssSyncService|RSS Sync Completed. Reports found: 40, Reports grabbed: 0
estaman
February 18, 2016, 1:33am
6
I think this is the developer tools log you wanted:
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help, check https://xhr.spec.whatwg.org/ .
http://andromeda.whatbox.ca:12927/vendor.js?h=ZRhiHils915Qd5G9/3bgNQ Failed to load resource: the server responded with a status of 401 (Unauthorized)send @ vendor.js?h=ZRhiHils915Qd5G9/3bgNQ:9824
vendor.js?h=ZRhiHils915Qd5G9/3bgNQ:22948 Uncaught Unauthorized
main.js?h=La+V0QLxDLV32571RSZReA:416 Uncaught TypeError: Cannot read property ‘extend’ of undefined
Looks like one of the JS files was cached incorrectly, in Chrome’s dev tools on the network tab check the Disable cache and then refresh the page.
estaman
February 18, 2016, 7:10am
8
Hmmm,
Still didn’t work. Got:
jquery.js:9664 GET http://andromeda.whatbox.ca:12927/api/config/ui 401 (Unauthorized)send @ jquery.js:9664jQuery.extend.ajax @ jquery.js:9215$.ajax @ jquery.ajax.js:21module.exports.get @ ApiData.js:722 @ UiSettingsModel.js:27__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:5020 @ FormatHelpers.js:3__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:5016 @ DateTime.js:3__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:5013 @ backbone.marionette.templates.js:3__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:5011 @ backbone.marionette.js:4__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:500 @ vendor.js:33__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:500 @ bootstrap 827148bc17bb2cf6191a:93(anonymous function) @ bootstrap 827148bc17bb2cf6191a:93
ApiData.js:13 Uncaught Unauthorized(anonymous function) @ ApiData.js:13fire @ jquery.js:3148self.add @ jquery.js:3194module.exports.get @ ApiData.js:1222 @ UiSettingsModel.js:27__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:5020 @ FormatHelpers.js:3__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:5016 @ DateTime.js:3__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:5013 @ backbone.marionette.templates.js:3__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:5011 @ backbone.marionette.js:4__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:500 @ vendor.js:33__webpack_require__ @ bootstrap 827148bc17bb2cf6191a:500 @ bootstrap 827148bc17bb2cf6191a:93(anonymous function) @ bootstrap 827148bc17bb2cf6191a:93
Are you able to change the port? It would be in /mnt/sdu1/jones/NzbDrone/Config.xml, getting a 401 response from the API is odd, that shouldn’t happen, also able to bring up API endpoints without supplying an API key, which isn’t possible.
A few things to try:
Try another port
Rename the config file so its regenerated
Re-install Sonarr
Which version of mono is installed?
system
Closed
April 18, 2016, 8:23am
10
