Sonarr version (exact version): 4.0.0.425
Mono version (if Sonarr is not running on Windows): .Net 6.0.13
OS: Docker
Debug logs: N/A
18mths ago Radarr changed from Nancy to AspNetCore, and I had to change my nginx config - [BUG]: 4.0.0.5371 breaks nginx reverse proxy · Issue #6676 · Radarr/Radarr · GitHub.
Some time after that the same happened with Sonarr. However, seemingly a few months ago (I’m only realising now that my config had reset, so I’m not sure when exactly) something changed and the default setup works fine again.
I’m looking to find out what it was and then see if Radarr would make the same change.
Ta!
