Sonarr version (3.0.9.1549):
**Mono version 5.20.1.34
OS: Synology NAS
Description of issue: / (/dev/root) nog maar 395 free space
Kan ik dat ergens aanpassen?
Is Sonarr installed locally or in a Docker container?
Sonarr is installed Locally.
Presumably it’s a permissions issue. What is Sonarr running as?
I don’t no what you mean with “What is Sonarr running as”
Sorry, what user and group are Sonarr running as?
Is this what you mean?
Contact the SynoCommunity for support on the third party app they support, fail to maintain, and fail to keep updated
But / having such limited storage would be correct. Guessing you don’t have any root folders add then since the storage listing shows the mounts of root folders as well
A month ago Sonarr is updated, so what do you mean?
I still have no answer, is there nobody who has this problem or issue?
